> Electrical Question #15 Need Help Please, I'm totally stumped this time
76-914
post Apr 6 2014, 06:33 PM
I'm going to have several electrical questions. 1st, Is pin #8, on the 14 pin plug at the relay board, the only switched 12v+ source in the engine compartment? TIA, Kent
post Nov 23 2014, 08:44 PM
Well guess what. The Suby Computer didn't like it one bit. It idled up n down between 500-1200rpm every 1.5-2 seconds. Disconnected that relay from the circuit and it idles normal again. I'll have to think about this one. It's very easy to reconnect that relay later if needed.
FWIW, it worked as intended as far as not starting in gear.
EDIT: I just had a thought. I'm pretty sure it was in reverse when the idle began to oscillate wildly. I shut it down immediately and removed the relay before confirming that it would do the same thing in forward or neutral! What if my backup lights let some voltage back thru the backup switch, which shares the same ground post and is located within 3" of the neutral switch.
76-914   Electrical Question #15 Need Help Please   Apr 6 2014, 06:33 PM
Mike Bellis   I'm going to have several electrical question...   Apr 6 2014, 07:38 PM
Jeff Bowlsby   Careful, not all model years are the same. Check ...   Apr 6 2014, 09:48 PM
Tom   I checked all of the schematics I can find and all...   Apr 7 2014, 03:04 AM
76-914   I checked all of the schematics I can find and al...   Apr 7 2014, 06:29 AM
76-914   Question #2 - Do I need to use a N/C relay off the...   Apr 7 2014, 06:37 AM
Tom   Kent, Don't know why as they don't dr...   Apr 7 2014, 11:37 AM
76-914   Damn, :chair: I didn't consider that the ECU ...   Apr 7 2014, 02:33 PM
76-914   #3 - What is the difference between a 5AG 30A fuse...   Apr 28 2014, 10:28 AM
Tom   Kent, The designations before the Amperage is f...   Apr 28 2014, 12:18 PM
76-914   Had to read thru some heavy stuff for my pea brain...   Apr 28 2014, 06:56 PM
Dtjaden   The easiest location for switched 12v on the relay...   Apr 29 2014, 08:39 AM
76-914   That could be useful info for someone that is usin...   Apr 29 2014, 08:59 AM
76-914   #4- I need to tie in my alt light with the suby en...   May 2 2014, 08:33 PM
Dave_Darling   Green/red would be the oil pressure light, not the...   May 2 2014, 10:07 PM
Mike Bellis   The alternator lamp work with 2 positive leads. On...   May 2 2014, 11:40 PM
Tom   That red/white that goes to fuse #9 on the fused s...   May 3 2014, 01:32 AM
76-914   Odd. I have one sch showing GR yet today I find th...   May 3 2014, 10:10 AM
Jeff Bowlsby   Odd. I have one sch showing GR yet today I find t...   May 3 2014, 11:05 AM
jrrhdmust   That diagram was superseded., it was not correct. ...   Jun 4 2014, 03:33 PM
76-914   #5 - If you own a 914 you know the importance of a...   Jun 4 2014, 01:54 PM
ClayPerrine   #5 - If you own a 914 you know the importance of ...   Aug 9 2021, 01:38 PM
76-914   #5 - If you own a 914 you know the importance of...   Aug 9 2021, 02:29 PM
stugray   Cut & paste from my response to another forum ...   Jun 4 2014, 02:04 PM
76-914   Not completely confused, yet. :D You state that t...   Jun 4 2014, 02:39 PM
Dave_Darling   The short answer, which is close enough for our pu...   Jun 4 2014, 03:30 PM
IGTARD   :shades2: :shades2: :shades2: :shades2: Jumping...   Jun 4 2014, 04:34 PM
Tom   Kent, Answer for your question about wire size fo...   Jun 4 2014, 05:54 PM
76-914   Kent, Answer for your question about wire size f...   Jun 5 2014, 09:07 AM
76-914   OK, another stupid electrical question. I have not...   Sep 18 2014, 07:26 PM
Spoke   If I use the single pole style, which requires th...   Sep 19 2014, 05:20 AM
Mike Bellis   Your steel chassis should still be a better ground...   Sep 18 2014, 09:30 PM
76-914   I have one chassis to tranny ground, 2 chassis to ...   Sep 19 2014, 08:44 AM
76-914   #7 - I need to connect my stock '73 back up li...   Nov 7 2014, 08:30 PM
Spoke   Use the negative side to switch the backup lights ...   Nov 7 2014, 09:35 PM
stugray   For my stock trans w/ custom harness, I just took ...   Nov 7 2014, 11:52 PM
76-914   Use the negative side to switch the backup lights...   Nov 8 2014, 06:41 PM
76-914   Will one of our electrical wizards help me out wit...   Nov 22 2014, 02:36 PM
Tom   Kent, What are you using the neutral switch for...   Nov 22 2014, 03:54 PM
76-914   Kent, What are you using the neutral switch fo...   Nov 22 2014, 07:39 PM
Spoke   Nice circuit. I redrew it to better follow the fl...   Nov 23 2014, 10:57 AM
76-914   Well guess what. The Suby Computer didn't like...   Nov 23 2014, 08:44 PM
Spoke   Well guess what. The Suby Computer didn't lik...   Nov 24 2014, 09:55 AM
Mike Bellis   I have found on my Audi conversion the ECU likes t...   Nov 24 2014, 08:48 AM
76-914   Spoke, no direct connections between the ECU and r...   Nov 24 2014, 09:02 PM
Tom   Kent, If the gear selector is in neutral, wi...   Nov 25 2014, 03:22 AM
76-914   That is exactly what I plan to do plus check it wi...   Nov 25 2014, 09:11 AM
76-914   I wanted an "in use" indicator light in ...   Jul 5 2015, 09:36 PM
Tom   Kent, If you have a meter, check the resista...   Jul 6 2015, 03:01 AM
Spoke   Kent, If you have a meter, check the resist...   Jul 6 2015, 05:59 AM
76-914   Over my head. <_< What is "I" in...   Jul 6 2015, 08:53 AM
Spoke   I is current in the LED and resistor. Here's a...   Jul 6 2015, 10:41 AM
76-914   A million thank you's. :worship:   Jul 6 2015, 02:30 PM
76-914   Question #10 - After someone posted a question re:...   Oct 19 2015, 10:56 PM
76-914   :bump: back to pg 1.   Oct 21 2015, 08:26 AM
76-914   Question #11 - I want to lower my AC fan speeds ab...   Jul 13 2016, 06:05 PM
Spoke   Question #11 - I want to lower my AC fan speeds a...   Jul 13 2016, 11:22 PM
914forme   Video on how to draw simple schematics Question ...   Jul 13 2016, 06:19 PM
76-914   Video on how to draw simple schematics Question...   Jul 13 2016, 06:51 PM
stugray   EDIT: OK, I watched the video and I already knew ...   Jul 13 2016, 10:34 PM
stugray   The resistor would work, but for about the same am...   Jul 14 2016, 07:08 AM
76-914   Stu and Jerry; thx a million. I can't wait to ...   Jul 14 2016, 07:31 AM
76-914   Post #13. I'm at a Baker's Dozen so I...   Jul 27 2017, 01:57 PM
76-914   Never mind. Nailed it. I ohmed out the fuse holder...   Jul 27 2017, 10:08 PM
Spoke   Good find. That looks like a cheap QC connector. T...   Jul 27 2017, 11:39 PM
76-914   Good find. That looks like a cheap QC connector. ...   Jul 28 2017, 08:31 AM
76-914   This is one of those subjects that the more I read...   Nov 20 2017, 07:38 PM
Spoke   This is one of those subjects that the more I rea...   Nov 22 2017, 07:59 PM
76-914   :bump:   Nov 22 2017, 09:58 AM
76-914   Thanks for answering. Electrical issues remind me ...   Nov 23 2017, 10:25 AM
Spoke   Thanks for answering. Electrical issues remind me...   Nov 23 2017, 11:13 AM
76-914   Went back thru it and no power from the black lead...   Nov 23 2017, 01:29 PM
76-914   Hey Spoke, the switch was definitely the problem. ...   Nov 24 2017, 02:36 PM
76-914   Electrical Problem #15 As stated - I'm totally...   Aug 8 2021, 05:28 PM
Spoke   Seems confusing as the foglight switch should not ...   Aug 8 2021, 06:41 PM
76-914   Jerry, With the switch pulled out - on position - ...   Aug 9 2021, 01:33 PM
Spoke   Jerry, With the switch pulled out - on position -...   Aug 10 2021, 11:34 AM
76-914   Jerry, With the switch pulled out - on position ...   Aug 10 2021, 04:15 PM
- Lo-Fi Version Time is now: 18th November 2026 - 09:17 PM
