> Is it impossible to run a type IV in closed loop?, Megasquirt
DNHunt
post May 1 2003, 08:46 PM
914 Wizard? No way. I got too much to learn.
After about a month of tuning I have a fueling map that seems close. Most of the map yields air fuel ratios of about 13.8. From what I have read this is about where the motor was designed to run and it runs very well.
However, I continue to have problems with overrun. Between 2600 and 3600 rpms under very light load the air fuel ratio is much richer. This is quite disappointing as I would hope to gain some economy here. The solution would seem to be closed loop with the oxygen sensor leaning out the air fuel mix. The problem is that the pulse widths are so short that O2 correction leads to large changes percentage wise in pulsewidth and fuel mix and the car bucks. I have one more idea to try. I am waiting on some new injectors since it feels as if one cylinder goes dry.
If that doesn't help, it appears to be run open loop and send fuel ou the exhaust or run closed loop and suffer some loss of smoothness.
I'd appreciate any advice,
Dave
DNHunt
post May 2 2003, 06:44 PM
Turned out it was an injector. # 2 hole had a bent pintel. I replaced it and the car was much better coming home. I'll max the VE table and make some corrections to the air density table (too lean when warming up ). Then add in O2 correction and we'll see what happens. I think it will still be a little rich at very high vacuum (20 Kpa and below) but not too bad.
Sorry I ragged on the engine designers. They were smarter than I gave them credit for. Maybe I should have given them credit for injectors that worked well for 28 years. Guess I'll take my crow with a little humility.
Dave
DNHunt   Is it impossible to run a type IV in closed loop?   May 1 2003, 08:46 PM
Mark Henry   I don’t have a clue if this will help you, i...   May 1 2003, 09:03 PM
airsix   Dave, I'm not familiar with the megasquirt, s...   May 1 2003, 11:58 PM
DNHunt   Mark and Ben Thanks for the help I do have the ...   May 2 2003, 07:06 AM
airsix     May 2 2003, 12:43 PM
DNHunt   Ben That silly little 0.2 ms pulsewidth change r...   May 2 2003, 01:52 PM
Brad Roberts   I'm not following along (MS denial) What rang...   May 2 2003, 02:06 PM
DNHunt   Turned out it was an injector. # 2 hole had a bent...   May 2 2003, 06:44 PM
rick 918-S   I have absollutely no idea what you are talking ab...   May 2 2003, 06:59 PM
DNHunt   Open loop means the fuel injection ECU does not us...   May 2 2003, 07:19 PM
Mark Henry
- Lo-Fi Version Time is now: 13th July 2025 - 06:49 PM
