> I need help guys!
porsche-tom
post Nov 25 2014, 02:06 PM
so i posted before about my about replacing my fuel pump because whenever its hot out it just stops. i cleaned out the gas tank, replaced the fuel lines and replaced the pump with a rotary fuel pump previously recommended. while on the ramps it started fine. i drove it out of the garage and one block away it died again (its about 85 degrees out). it now will not start but i can hear the pump kicking on when ever i turn the key. i am going to wait until tonight when its cooler out and see if it changes but im getting pretty frustrated (IMG:style_emoticons/default/headbang.gif) . does anybody have any ideas?.....please
1972 1.7 carb convert
r_towle
post Nov 25 2014, 02:08 PM
Custom Member
fuel lines swapped backwards.
You want to have the feed line for the pump to be the larger of the two, closer to the passenger side of the car when looking from below.
Are you out of fuel also?
If you swapped the line, and its low, it may work when jacked up in the back because the return line is about 4 inches tall inside the tank.
The correct feed line is at the bottom of the tank.
Rich
porsche-tom   I need help guys!   Nov 25 2014, 02:06 PM
r_towle   fuel lines swapped backwards. You want to have the...   Nov 25 2014, 02:08 PM
porsche-tom   the return line was previously blocked off. the li...   Nov 25 2014, 02:26 PM
r_towle   the return line was previously blocked off. the l...   Nov 25 2014, 06:05 PM
wndsnd   If it is a carbed car, someone had to jump the pum...   Nov 25 2014, 02:41 PM
Racer Chris   check for a kinked hose.   Nov 25 2014, 02:53 PM
jvmarino   You may also want to check the fuses on the relay ...   Nov 25 2014, 03:00 PM
RobW   You don't mention changing the fuel filter...   Nov 25 2014, 03:23 PM
porsche-tom   filter is new came with the pump.   Nov 25 2014, 03:40 PM
GeorgeRud   Is the fuel pump in the original position or has i...   Nov 25 2014, 03:44 PM
porsche-tom   the pump was already relocated to the front under ...   Nov 25 2014, 03:48 PM
stugray   If the tank vents are clogged, it can pull a vacuu...   Nov 25 2014, 05:21 PM
Mark Henry   In-tank filter screen?   Nov 25 2014, 05:55 PM
rhodyguy   note the carb conversion comment. pull the supply ...   Nov 25 2014, 06:11 PM
r_towle   note the carb conversion comment. pull the supply...   Nov 25 2014, 06:14 PM
rhodyguy   sounds like a plan. :D   Nov 25 2014, 06:18 PM
porsche-tom   i am going to try and lift up the gas tank and try...   Nov 25 2014, 06:40 PM
porsche-tom   i lifted the tank to unkink any kinks and tried to...   Nov 25 2014, 07:25 PM
wndsrfr   i lifted the tank to unkink any kinks and tried t...   Nov 25 2014, 07:52 PM
wndsnd   Well I know what I would do but it is probably not...   Nov 25 2014, 07:35 PM
r_towle   Sorry, pull the tank.   Nov 25 2014, 08:05 PM
cwpeden   In your tank you will one of these. The top one w...   Nov 25 2014, 08:23 PM
wndsrfr   In your tank you will one of these. The top one ...   Nov 26 2014, 07:40 AM
bandjoey   Sometimes it's eliminate possible problems one...   Nov 26 2014, 08:06 AM
Mikey914   Really easy to pinch a hose. I had exactly this pr...   Nov 26 2014, 09:30 AM
cwpeden   So how did it turn out?   Dec 8 2014, 01:47 AM
- Lo-Fi Version Time is now: 26th June 2026 - 09:29 PM
