| porsche-tom |
Nov 25 2014, 02:06 PM
Member ![]() ![]() Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None |
so i posted before about my about replacing my fuel pump because whenever its hot out it just stops. i cleaned out the gas tank, replaced the fuel lines and replaced the pump with a rotary fuel pump previously recommended. while on the ramps it started fine. i drove it out of the garage and one block away it died again (its about 85 degrees out). it now will not start but i can hear the pump kicking on when ever i turn the key. i am going to wait until tonight when its cooler out and see if it changes but im getting pretty frustrated (IMG:style_emoticons/default/headbang.gif) . does anybody have any ideas?.....please
1972 1.7 carb convert |
| EdwardBlume |
Nov 25 2014, 03:23 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
You don't mention changing the fuel filter...
porsche-tom I need help guys! Nov 25 2014, 02:06 PM
r_towle fuel lines swapped backwards.
You want to have the... Nov 25 2014, 02:08 PM
porsche-tom the return line was previously blocked off. the li... Nov 25 2014, 02:26 PM
r_towle
the return line was previously blocked off. the l... Nov 25 2014, 06:05 PM
wndsnd If it is a carbed car, someone had to jump the pum... Nov 25 2014, 02:41 PM
Racer Chris check for a kinked hose. Nov 25 2014, 02:53 PM
jvmarino You may also want to check the fuses on the relay ... Nov 25 2014, 03:00 PM
porsche-tom filter is new came with the pump. Nov 25 2014, 03:40 PM
GeorgeRud Is the fuel pump in the original position or has i... Nov 25 2014, 03:44 PM
porsche-tom the pump was already relocated to the front under ... Nov 25 2014, 03:48 PM
stugray If the tank vents are clogged, it can pull a vacuu... Nov 25 2014, 05:21 PM
Mark Henry In-tank filter screen? Nov 25 2014, 05:55 PM
rhodyguy note the carb conversion comment. pull the supply ... Nov 25 2014, 06:11 PM
r_towle
note the carb conversion comment. pull the supply... Nov 25 2014, 06:14 PM
rhodyguy sounds like a plan. :D Nov 25 2014, 06:18 PM
porsche-tom i am going to try and lift up the gas tank and try... Nov 25 2014, 06:40 PM
porsche-tom i lifted the tank to unkink any kinks and tried to... Nov 25 2014, 07:25 PM
wndsrfr
i lifted the tank to unkink any kinks and tried t... Nov 25 2014, 07:52 PM
wndsnd Well I know what I would do but it is probably not... Nov 25 2014, 07:35 PM
r_towle Sorry, pull the tank. Nov 25 2014, 08:05 PM
cwpeden In your tank you will one of these.
The top one w... Nov 25 2014, 08:23 PM
wndsrfr
The top one ... Nov 26 2014, 07:40 AM
bandjoey Sometimes it's eliminate possible problems one... Nov 26 2014, 08:06 AM
Mikey914 Really easy to pinch a hose. I had exactly this pr... Nov 26 2014, 09:30 AM
cwpeden So how did it turn out? Dec 8 2014, 01:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2026 - 09:28 PM |
