> I need help guys!
porsche-tom
post Nov 25 2014, 02:06 PM
so i posted before about my about replacing my fuel pump because whenever its hot out it just stops. i cleaned out the gas tank, replaced the fuel lines and replaced the pump with a rotary fuel pump previously recommended. while on the ramps it started fine. i drove it out of the garage and one block away it died again (its about 85 degrees out). it now will not start but i can hear the pump kicking on when ever i turn the key. i am going to wait until tonight when its cooler out and see if it changes but im getting pretty frustrated (IMG:style_emoticons/default/headbang.gif) . does anybody have any ideas?.....please
1972 1.7 carb convert
porsche-tom
post Nov 25 2014, 03:48 PM
the pump was already relocated to the front under the tank and i intstalled the new one in the same spot
porsche-tom   I need help guys!   Nov 25 2014, 02:06 PM
r_towle   fuel lines swapped backwards. You want to have the...   Nov 25 2014, 02:08 PM
porsche-tom   the return line was previously blocked off. the li...   Nov 25 2014, 02:26 PM
r_towle   the return line was previously blocked off. the l...   Nov 25 2014, 06:05 PM
wndsnd   If it is a carbed car, someone had to jump the pum...   Nov 25 2014, 02:41 PM
Racer Chris   check for a kinked hose.   Nov 25 2014, 02:53 PM
jvmarino   You may also want to check the fuses on the relay ...   Nov 25 2014, 03:00 PM
RobW   You don't mention changing the fuel filter...   Nov 25 2014, 03:23 PM
porsche-tom   filter is new came with the pump.   Nov 25 2014, 03:40 PM
GeorgeRud   Is the fuel pump in the original position or has i...   Nov 25 2014, 03:44 PM
porsche-tom   the pump was already relocated to the front under ...   Nov 25 2014, 03:48 PM
stugray   If the tank vents are clogged, it can pull a vacuu...   Nov 25 2014, 05:21 PM
Mark Henry   In-tank filter screen?   Nov 25 2014, 05:55 PM
rhodyguy   note the carb conversion comment. pull the supply ...   Nov 25 2014, 06:11 PM
r_towle   note the carb conversion comment. pull the supply...   Nov 25 2014, 06:14 PM
rhodyguy   sounds like a plan. :D   Nov 25 2014, 06:18 PM
porsche-tom   i am going to try and lift up the gas tank and try...   Nov 25 2014, 06:40 PM
porsche-tom   i lifted the tank to unkink any kinks and tried to...   Nov 25 2014, 07:25 PM
wndsrfr   i lifted the tank to unkink any kinks and tried t...   Nov 25 2014, 07:52 PM
wndsnd   Well I know what I would do but it is probably not...   Nov 25 2014, 07:35 PM
r_towle   Sorry, pull the tank.   Nov 25 2014, 08:05 PM
cwpeden   In your tank you will one of these. The top one w...   Nov 25 2014, 08:23 PM
wndsrfr   In your tank you will one of these. The top one ...   Nov 26 2014, 07:40 AM
bandjoey   Sometimes it's eliminate possible problems one...   Nov 26 2014, 08:06 AM
Mikey914   Really easy to pinch a hose. I had exactly this pr...   Nov 26 2014, 09:30 AM
cwpeden   So how did it turn out?   Dec 8 2014, 01:47 AM
- Lo-Fi Version Time is now: 26th June 2026 - 09:27 PM
