| porsche-tom |
Nov 25 2014, 02:06 PM
Member ![]() ![]() Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None |
so i posted before about my about replacing my fuel pump because whenever its hot out it just stops. i cleaned out the gas tank, replaced the fuel lines and replaced the pump with a rotary fuel pump previously recommended. while on the ramps it started fine. i drove it out of the garage and one block away it died again (its about 85 degrees out). it now will not start but i can hear the pump kicking on when ever i turn the key. i am going to wait until tonight when its cooler out and see if it changes but im getting pretty frustrated (IMG:style_emoticons/default/headbang.gif) . does anybody have any ideas?.....please
1972 1.7 carb convert |
| porsche-tom |
Nov 25 2014, 02:26 PM
the return line was previously blocked off. the lines are in the correct places and it has 2 gallons of fuel that should be enough fuel?
| r_towle |
Nov 25 2014, 06:05 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
the return line was previously blocked off. the lines are in the correct places and it has 2 gallons of fuel that should be enough fuel? It's a fuel problem. So you state that you had it working before with no issues with the current hose. It's either out of gas and not enough to get into the line, or its a kinked hose from when you put the tank back in after install. It can work by using the return line, but it's about 2 gallons of fuel cause of the 4 inch pipe in the tank. That is why I said you may have swapped hoses... You said it worked while jacked up, did not work when on the ground....So it's a fuel level issue. Could also be a kink Get a mirror and verify there is no kink. If you are patient with a mirror and flashlight, you can see almost all of it except the loop that goes toward the drivers side from the pump to the filter if it's in the 75/76 location. Not a typical place to kink...more likely to kink right under the tank and sometimes you just need to loop it the right way from underneath and it will be ok. Other times you need to pull the tank and do it again... Tests I would do. Is there fuel in the engine bay when the pump is running? Should be a 65 psi stream of fuel...squirt it into a gas can. If no fuel there, start looking for the kink. Look for the kink first before you add more fuel to the tank. You may need to pull up the tank to fix the kink. |
porsche-tom I need help guys! Nov 25 2014, 02:06 PM
r_towle fuel lines swapped backwards.
You want to have the... Nov 25 2014, 02:08 PM
wndsnd If it is a carbed car, someone had to jump the pum... Nov 25 2014, 02:41 PM
Racer Chris check for a kinked hose. Nov 25 2014, 02:53 PM
jvmarino You may also want to check the fuses on the relay ... Nov 25 2014, 03:00 PM
RobW You don't mention changing the fuel filter... Nov 25 2014, 03:23 PM
porsche-tom filter is new came with the pump. Nov 25 2014, 03:40 PM
GeorgeRud Is the fuel pump in the original position or has i... Nov 25 2014, 03:44 PM
porsche-tom the pump was already relocated to the front under ... Nov 25 2014, 03:48 PM
stugray If the tank vents are clogged, it can pull a vacuu... Nov 25 2014, 05:21 PM
Mark Henry In-tank filter screen? Nov 25 2014, 05:55 PM
rhodyguy note the carb conversion comment. pull the supply ... Nov 25 2014, 06:11 PM
r_towle
note the carb conversion comment. pull the supply... Nov 25 2014, 06:14 PM
rhodyguy sounds like a plan. :D Nov 25 2014, 06:18 PM
porsche-tom i am going to try and lift up the gas tank and try... Nov 25 2014, 06:40 PM
porsche-tom i lifted the tank to unkink any kinks and tried to... Nov 25 2014, 07:25 PM
wndsrfr
i lifted the tank to unkink any kinks and tried t... Nov 25 2014, 07:52 PM
wndsnd Well I know what I would do but it is probably not... Nov 25 2014, 07:35 PM
r_towle Sorry, pull the tank. Nov 25 2014, 08:05 PM
cwpeden In your tank you will one of these.
The top one w... Nov 25 2014, 08:23 PM
wndsrfr
The top one ... Nov 26 2014, 07:40 AM
bandjoey Sometimes it's eliminate possible problems one... Nov 26 2014, 08:06 AM
Mikey914 Really easy to pinch a hose. I had exactly this pr... Nov 26 2014, 09:30 AM
cwpeden So how did it turn out? Dec 8 2014, 01:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2026 - 10:36 PM |
