> I need some testing help, Free Parts!
McMark
post Nov 25 2014, 07:32 PM
914 Freak!
While playing with my MicroSquirt kits I found that the stock CHT has a quite frequent failure rate. I used a stock unit on the motor I installed and on my trip to Portland I realized it was giving lots of erroneous readings. When I got back I installed another one, and it was fine for awhile, but eventually started giving the same erroneous readings. I found a modern electronic component which replicates the stock resistance/temp curve of the CHT sensor and isn't prone to vibration/heat damage like the stock unit (including new replacements). I would like to find someone who drives their car enough to notice if there is a difference.
Who's got stock D-Jet installed on their system, drives somewhat regularly and is willing to do some testing? (IMG:style_emoticons/default/beerchug.gif)
914werke
post Nov 26 2014, 11:57 AM
Mark can you elaborate?
Were these variances something you noticed looking at a map or glitches in drivability that led you to the CHT & observe issues with their resistance/temp curve?
McMark
post Nov 26 2014, 03:51 PM
914 Freak!
QUOTE(rdauenhauer @ Nov 26 2014, 09:57 AM) *
Since I'm running MicroSquirt I can graph the readings. I was getting a bit of bucking, each time the reading jumped it would squirt a bunch of fuel. The first one stopped reading all together and just had high resistance, so the engine always thought it was cold. Thankfully I had my laptop with me so I just turned off the cold-start enrichment and ignored the sensor. The second failure was similar, but never got to the worst case scenario. It would buck occasionally - just a quick miss and then back to normal.
- Lo-Fi Version Time is now: 1st July 2025 - 03:44 PM
