1971 no horn need help, Electrical help |
mr2by4 |
Nov 15 2014, 01:38 PM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
I seem to be missing a wire of some sort or a connection. With the wheel mounted I can't make any connection. Here is what is under the wheel in my 71. Am I missing something or am I just not making a good connection between the ring and the electrical pick up?
Attached thumbnail(s) |
mepstein |
Nov 26 2014, 09:34 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It should go in the hole on the right hand side of the hub, not the center. It's the only hole on the metal bracket on the face of the hub.
The bottom of the horn plunger will run against the metal disc on the steering column. As shown in your first pic |
mr2by4 |
Nov 26 2014, 09:40 PM
It should go in the hole on the right hand side of the hub, not the center. It's the only hole on the metal bracket on the face of the hub. The bottom of the horn plunger will run against the metal disc on the steering column. As shown in your first pic That explains much! Thanks the exploded parts view just showed everything exploded. I will try to sneak by and try that tomorrow! (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 03:08 PM |
