> Should I get new carbs on my /6 2.2l 911e motor?
tornik550
post Nov 27 2014, 01:55 PM
I recently purchased a 911e 2.2l engine. Befor I install it in my 914, should I change carbs? A previous owner at some point changed from MFI to zenith 40 tin carbs. From my understanding, this is probably not the best setup for a 911e 2.2? I have looked at the different options, which do you think is most appropriate taking cost, hp/torque gains, drivability...
1. Leave the zenith carbs
Pros- I already have them
Cons- probably better forming options
2. Change back to MFI
I probably can't do this one. I have no where to obtain the setup and I really am more comfortable with carbs
3. Change to weber 40 Ida's
Pros- ? Power?
Cons- expensive. Most likely between $2000-$2500 after rebuild
4. PMO carbs
Pros- improved overall performance compared with the zeniths. Easy setup. Is it worth the cost?
Cons- very expensive-$3600.
Here are some other things that I am doing to the engine other than basic maintenance. Pertronix for the distributor, new plug wires (clewett), msd 6al (I already had this), msds headers.
I do not plan on racing this car anymore, just spirited street driving.
Mark Henry
post Nov 28 2014, 03:47 PM
that's what I do!
Almost everyone that has issues with carbs have no clue of how to set them up in the first place. With dual carbs a lot of the time it's a linkage issue, then ignition, jetting, vacumn leaks and lastly the engine is just plain beat.
MFI is great... but have you seen the prices peeps are asking for them (IMG:style_emoticons/default/blink.gif)
Stay the course with the carbs you have, get it running, see how it runs and then research and decide if you want to try something else.
BTW If one was to go EFI you could always gut and mod the zeniths to be TB's (IMG:style_emoticons/default/idea.gif)
tornik550   Should I get new carbs on my /6 2.2l 911e motor?   Nov 27 2014, 01:55 PM
type47   None of the above. I think you should do a single ...   Nov 27 2014, 04:50 PM
matthepcat   I agree with the above. I have a 2.2s motor with w...   Nov 27 2014, 05:19 PM
Mark Henry   Is it a running engine? If it is clean and get it...   Nov 27 2014, 05:29 PM
tornik550   The engine is a very clean, running engine. I sup...   Nov 27 2014, 05:43 PM
type47   I would like FI but $6500 is a lot of cash. ...   Nov 27 2014, 07:22 PM
johnhora   Is it a running engine? If it is clean and get i...   Nov 27 2014, 08:53 PM
ClayPerrine   If you were closer, I would help you with the MFI....   Nov 27 2014, 09:11 PM
Mark Henry   I see you have an ad wanting webers, I'd reall...   Nov 28 2014, 12:06 AM
roblav1   I am one of the guys who said that the Zeniths are...   Nov 28 2014, 12:34 AM
Tom_T   IMHO if it were mine then I'd go back to the M...   Nov 28 2014, 01:47 PM
mepstein   IMHO if it were mine then I'd go back to the ...   Nov 28 2014, 01:58 PM
JmuRiz   Never heard of people having issues with new PMO c...   Nov 28 2014, 02:46 PM
Mark Henry   Almost everyone that has issues with carbs have no...   Nov 28 2014, 03:47 PM
stownsen914   I'm a DIYer and have tuned PMOs and MFI on two...   Nov 29 2014, 07:12 AM
PancakePorsche   FWIW, I dicked for months trying to get a used set...   Dec 2 2014, 02:47 AM
9146986   Good carbs are not that difficult to tune, includi...   Dec 2 2014, 07:21 AM
- Lo-Fi Version Time is now: 3rd July 2025 - 08:15 PM
