| trojanhorsepower |
Nov 9 2014, 07:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Search is not my friend. Has there been a long drawn out thread about SPI epoxy primer? If so please point me to it. I don't want to stir the pot, just looking for information. I have found a lot about using it on their forum, but it is a little cult like over there. Just hoping to get a range of opinions.
| scotty b |
Nov 29 2014, 09:19 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
That Devillbiss is a good all around setup. Much better then anything you'll get at HF, Lowes etc.
JP371, bondo, spray poly if so desired, or just move onto the JP202, base, clear. There's no need for 335 JP202 can be mixed either as a build primer for filling scratches, or thinned and shot as a sealer so there is no need in a " sealer " only product. PPG K-36 is the same way. |
trojanhorsepower SPI Nov 9 2014, 07:05 PM
dlee6204 I've used their epoxy stuff with overall good ... Nov 9 2014, 07:15 PM
trojanhorsepower Thanks Doug,
I will definitely try it out when the... Nov 9 2014, 07:27 PM
scotty b From personal experience. I do not like " off... Nov 9 2014, 07:34 PM
trojanhorsepower Thanks Scotty,
Do you wash the Ospho, or just let ... Nov 9 2014, 08:11 PM
scotty b
Thanks Scotty,
Do you wash the Ospho, or just let... Nov 9 2014, 08:45 PM
roblav1 PPG DP epoxies are the way to go. Nov 9 2014, 08:32 PM
trojanhorsepower OK. So would you put ospho on all metal or just o... Nov 9 2014, 09:00 PM
scotty b I normally just put it over old to make certain an... Nov 9 2014, 09:08 PM
trojanhorsepower I see that Shopline lists body filler as a compati... Nov 11 2014, 09:30 AM
scotty b
I see that Shopline lists body filler as a compat... Nov 11 2014, 12:43 PM
trojanhorsepower So is it safe to just use all the products in the ... Nov 28 2014, 08:43 PM
Rob-O I used PPG's DP products, great stuff.
As f... Nov 28 2014, 09:04 PM
trojanhorsepower http://www.ebay.com/itm/New-DeVILBISS-Fini...t-/39... Nov 29 2014, 08:31 PM
trojanhorsepower Thanks Guys!
Sounds like I have a plan. Nov 30 2014, 04:48 PM
trojanhorsepower After looking more closely at what my compressor c... Apr 22 2015, 07:38 PM
bulitt Last time I tried to buy shop line the distributor... Apr 22 2015, 08:15 PM
cary Same with my PPG shop. Deltron and Omni only.
So I... Apr 22 2015, 08:29 PM
trojanhorsepower I checked at napa when I started this thread and t... Apr 23 2015, 07:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:41 AM |
