Easyb |
Member ![]() ![]() Group: Members Posts: 51 Joined: 13-October 14 From: Houston Member No.: 18,016 Region Association: None ![]() |
I'm rebuilding a rear caliper one a 76 914 using existing parts and the small rebuild kit from PMB and their very helpful YouTube video.
The issue I'm facing is that the clip the lock the spring and seat in the inner tensioner is not staying in place (the clip isn't). I'm able to push the pin in and it stays until in install the piston and I push it in then i can hear the clip pop out and the tensioner doesn't align with the hole in the gear and the piston can't be adjusted properly. Just spent several hours dealing with it. There is one obvious damage to the components and I was able to rebuild the rear driver side caliper without much issues. This caliper had a frozen piston that was grinding the brake pad. Piston inner parts appear ok and I had them out and cleaned them before resetting them inside the piston. Does anyone have any suggestions? Have you experienced this before? Thanks in advance. Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 23rd September 2025 - 02:33 AM |
