> Oil Temperature Gauge(s)...so what do I have here?
GregAmy
post Nov 30 2014, 11:16 AM
I've got a '74 2L, 4742918315. Thing was a rebuildable basket case when I got it, been hacking away...today's task was the center oil temperature gauge: it doesn't work.
In reviewing the wiring diagram it appears that I should have a green/black wire running from the sensor at the bottom of the engine to a green/black wire in the center console. However, while I have the red/white and brown wires going to the gauge, the third wire is...white. I used a VOM to ring out the white wire, and it does not go to the sensor wire in the engine compartment.
But here's another odd thing: the car also has a fuel combination gauge ("silver button") with a temp sensor in it. In reviewing various pages on the web, I'm thinking that's not what's supposed to be in this car; best I can tell, this car with a center console oil temp gauge should have a blank area at the top of the fuel combo gauge.
- What do I have here? Is this a center console that someone added on? It has an operational clock and voltmeter (which sucks, by the way).
- If this is the case, what is the plug with the white wire supposed to be for? I don't see anything obvious in the wiring diagram, there's no voltage to this wire, nor does it ring to ground at all.
Stumped, but intrigued...
Greg
Dave_Darling
post Nov 30 2014, 08:48 PM
914 Idiot
Your car seems to be a late 74, so the silver-button 73-style gauge is wrong. Someone swapped it in. They may have connected the oil temp gauge there, or they may not.
There is a connector under the rear of the center console with several wires on each side. One of them should be the green/black signal wire. If there is something plugged into it, that's likely going up to the gauge in your combo gauge.
The white wire is certainly an addition. The only way you'll figure out where it goes is to trace it yourself.
--DD
GregAmy
post Nov 30 2014, 09:02 PM
Thanks Dave. You sure about that white wire? Except for the white color, it looks decisively factory, using the stock plugs, stock electrical pin inserts, and it goes into and through a factory wiring loom with all the other wires in that vicinity. Based on the other hacking I've seen on this car, it's not the quality of work I'd expect from someone swapping something in...in fact, the quality of its insertion lends me to believe it was done at the factory.
- Lo-Fi Version Time is now: 8th July 2025 - 09:53 PM
