lsintampa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States ![]() |
75 914-4 FI
My headlights work great, with one exception. When I try to manually open the lights, they open about 1/4" then the motor spins on its own to full open then to full close. Seems odd to me, because I've opened and closed them before and never had an issue. The only thing I've done lately is to hook up an electric water pump for the windshield washer - tied into the black/brown wire and it operates from the inside wiper arm by pulling it towards you. Washer motor works just fine. Can't think it's in any way related, but hey - I always consider the last thing you fix may break something else. ???? Thanks, Len |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,209 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The behavior is normal, or at least pretty close to normal. Exactly where in the travel the "close" circuit takes over seems to vary, but it's the same functionality. Depends on the adjustment of the microswitches inside the motor or linkage.
You can pull the headlight motor relay to keep the light in whatever position you set it. Or disconnect the car's battery. You might also be able to disable the close function by pulling the headlight switch out one notch? I think I remember doing that with my 74, at least. --DD |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,786 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
The behavior is normal, or at least pretty close to normal. Exactly where in the travel the "close" circuit takes over seems to vary, but it's the same functionality. Depends on the adjustment of the microswitches inside the motor or linkage. You can pull the headlight motor relay to keep the light in whatever position you set it. Or disconnect the car's battery. You might also be able to disable the close function by pulling the headlight switch out one notch? I think I remember doing that with my 74, at least. --DD If you spin the knob in "the other direction" you'll soon have the knob in your hand. |
Lo-Fi Version | Time is now: 1st August 2025 - 04:58 AM |
