> Fuel Evaporative Control System Plastic Line Help, (Charcoal Canister) Hose Routing
914four
post Dec 6 2014, 09:38 AM
I have a late 1974 2.0 with the evaporative control system (charcoal canister) mounted in the engine bay back wall. The small plastic line runs from the back wall of the engine bay through the center tunnel to the gas tank compartment along the same route as the fuel lines.
After putting my car back together during a rotisserie restoration I realized the small plastic line was not in the gas tank compartment. This was after I installed the gas tank and front hood. The small plastic line was likely pulled back into the center tunnel when I pulled out the plastic fuel lines and installed new stainless steel lines. The engine compartment portion of the plastic line is still there and seems to have the correct amount of line coming out of the center tunnel.
I would like to keep the evoporative control system functional if possible. Is there a reasonable way to find and pull out the plastic line or should I try to run a new line in the same location or maybe a different location? Is it likely the plastic line is kinked and will not be functional if I can find it and pull it out? Is there a better way to do this?
Kelvin
post Dec 6 2014, 09:42 AM
914-6 GT in waiting
I thought all the evap lines ran up the left long, not the tunnel.
914four
post Dec 6 2014, 09:49 AM
QUOTE(mepstein @ Dec 6 2014, 09:42 AM) *
There were several locations for the canister and routes for the lines. It depends on the year and time of the year the car was built (e.g., early and late '74 MY cars were different).
- Lo-Fi Version Time is now: 12th June 2026 - 12:50 AM
