| malcolm2 |
Dec 8 2014, 07:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
If needed I'll shoot a little video. But here is what I found. The upper section is holding firm. I can grab the lower section just below the upper and move it, significantly. It looks to be moving inside the upper section. The top nut is tight (viewed in the front trunk), I don't see any movement there.
This is a shot of the passenger side. it is moving the most. The drivers side only moves slightly. Not enough to notice the rotor etc... moving like on this side. Of course it is the bumpy roads, turning in driveways, etc... that make the noises as I am driving. Say the word and I'll shoot a video. You can hear the clanking. ![]() |
| SirAndy |
Dec 8 2014, 07:08 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,453 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The top part is just a dust cover and not really part of the shock.
Well, the top of the dust cover acts as a large washer against the rubber top mounts, so don't remove it permanently. Anyways, if you unbolt the top of the shock and slide it down, there should be a threaded insert where the shaft comes out of the shock, which may have come lose and needs to be tightened again. The shock could also be broken, in which case the shaft will have a lot of side to side movement even with the insert tightened down. (IMG:style_emoticons/default/idea.gif) |
malcolm2 Front end rattle Dec 8 2014, 07:03 PM
SirAndy Oh, and only unbolt the large top shock nut!
... Dec 8 2014, 07:11 PM
malcolm2
... Dec 8 2014, 07:23 PM
bdstone914
Oh, and only unbolt the large top shock nut... Dec 8 2014, 07:26 PM
wndsnd The nut inside the strut that Andy is talking abou... Dec 8 2014, 07:21 PM
malcolm2
The nut inside the strut that Andy is talking abo... Dec 8 2014, 07:25 PM
r_towle It's easier if you remove the anti sway bar dr... Dec 8 2014, 08:09 PM
malcolm2
It's easier if you remove the anti sway bar d... Dec 8 2014, 09:29 PM
malcolm2 Another successful repair. I am sure I would have... Dec 8 2014, 08:12 PM
r_towle
I first broke the 200HP mark on pump gas in 1996... Dec 8 2014, 09:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 03:04 AM |
