> Front end rattle, Is something worn out?
malcolm2
post Dec 8 2014, 07:03 PM
If needed I'll shoot a little video. But here is what I found. The upper section is holding firm. I can grab the lower section just below the upper and move it, significantly. It looks to be moving inside the upper section. The top nut is tight (viewed in the front trunk), I don't see any movement there.
This is a shot of the passenger side. it is moving the most. The drivers side only moves slightly. Not enough to notice the rotor etc... moving like on this side. Of course it is the bumpy roads, turning in driveways, etc... that make the noises as I am driving.
Say the word and I'll shoot a video. You can hear the clanking.
wndsnd
post Dec 8 2014, 07:21 PM
You wanted a horse, but got a goat. Nobody wants a goat....
The nut inside the strut that Andy is talking about can come loose and if it loosens enough the strut will make a banging noise over bumps. I had to use a little Blue Loctite on mine, just for my piece of mind.
Then again it could be your ball joint.
John
malcolm2
post Dec 8 2014, 07:25 PM
QUOTE(wndsnd @ Dec 8 2014, 07:21 PM) *
John
Everything, and I mean everything is new. the total car has 7,000 miles on it. the ball joint could be bad, but I have zero movement at the bottom while shaking the top.
- Lo-Fi Version Time is now: 4th March 2026 - 04:26 AM
