> Front end rattle, Is something worn out?
malcolm2
post Dec 8 2014, 07:03 PM
If needed I'll shoot a little video. But here is what I found. The upper section is holding firm. I can grab the lower section just below the upper and move it, significantly. It looks to be moving inside the upper section. The top nut is tight (viewed in the front trunk), I don't see any movement there.
This is a shot of the passenger side. it is moving the most. The drivers side only moves slightly. Not enough to notice the rotor etc... moving like on this side. Of course it is the bumpy roads, turning in driveways, etc... that make the noises as I am driving.
Say the word and I'll shoot a video. You can hear the clanking.
post Dec 8 2014, 07:11 PM
Resident German
Oh, and only unbolt the large top shock nut!
Don't unbolt the plates holding the top in place unless you want to do a full alignment of the car anyways.
malcolm2
post Dec 8 2014, 07:23 PM
QUOTE(SirAndy @ Dec 8 2014, 07:11 PM) *
I was aware of that.
Once the top nut is off, will I be able to move the control arm down far enough to get the shock (or strut) out of the upper plate (that I am not removing)? we are just talking about a few inches, right? It has been a couple years since I had this whole thing apart and my memory is just not that good.
bdstone914
post Dec 8 2014, 07:26 PM
bdstone914
QUOTE(malcolm2 @ Dec 8 2014, 07:23 PM) *
Yes you can compress the strut and lean it outside the fender to access the top nut. Just jack up that side of the car and the control arm will pivot downward.
- Lo-Fi Version Time is now: 4th March 2026 - 03:04 AM
