| GregAmy |
Dec 13 2014, 09:34 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Anyone have a link to a detailed carpet installation how-to? I bought the carpet kit, floor vinyl, and sill trim from 914Rubber, but my '74 came with nothing on the floors, just bare metal with some kind of thin adhesive-backed sound deadener. I've got these pieces all laid out on my garage floor and other than the obvious overlay carpet pieces I'm clueless as to where all this goes and how it is attached (I'm guessing 3M spray adhesive?)
Experiences appreciated. GA |
| Mikey914 |
Dec 13 2014, 10:21 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
The long unbound pieces go on the inside rockers, they are pre cut for the seatbelt holes so that will help with left and right. The kidney shaped one with the slot cut goes at the drivers side wheel well, the slot is where the speaker mount is. The almost rectangle with the C cut out is where the steering linkage passes through. The 12" dog bone shape is one the open area on the bulkhead next to it.
The center console section has a shifter hole, and the front drivers and passenger's mats , well you can figure that one. The rears are almost the same with the parking brake cut out. The vinyl is a little harder to explain. I do 6 piece vinyl kit, so the thin strips go between the back pad and the inner door seals. I did post awhile back for the other 4 pcs, I know search sucks, but you might be able to find it Mark |
GregAmy Carpet Installation How-To? Dec 13 2014, 09:34 AM
RobW The carpet is fairly straight forward. The problem... Dec 13 2014, 09:38 AM
mepstein You might want to pick up a cheap heat gun Dec 13 2014, 09:38 AM
altitude411 ^^^^* respect*^^^^ for a great vendor.... :first: ... Dec 13 2014, 10:31 AM
GregAmy Amen... ;)
So take a peek at these photos, see if... Dec 13 2014, 11:16 AM
Mikey914
Amen... ;)
So take a peek at these photos, see i... Dec 13 2014, 09:23 PM
GregAmy Never mind on the vinyl floor instructions; the ph... Dec 13 2014, 12:44 PM
bandjoey I didn't glue anything Down for ease if cleani... Dec 13 2014, 01:16 PM
AvalonFal
I didn't glue anything Down for ease if clean... Dec 13 2014, 03:39 PM
stevegm
I didn't glue anything Down for ease if clea... Dec 13 2014, 03:44 PM
AvalonFal Before trim installed.
Dec 13 2014, 06:24 PM
stevegm
Looks good. Did you ... Dec 13 2014, 08:21 PM
clapeza The carpet tape also works well for sticking down ... Dec 13 2014, 08:09 PM
Larmo63 I did mine recently, and it wasn't hard to do.... Dec 13 2014, 08:46 PM
GregAmy All done, thanks for the help! It was a tad fu... Dec 14 2014, 05:16 PM
Mikey914 They were stock. part of the floor pan. I haven... Dec 15 2014, 01:20 AM
porsche913b_sp Where do you get carpet tape, Lowes, Home Depot or... Dec 15 2014, 02:31 PM
AvalonFal
Where do you get carpet tape, Lowes, Home Depot o... Dec 15 2014, 03:33 PM
Rob-O I just did mine too, used Mark's German Loop s... Dec 15 2014, 03:53 PM
GregAmy I didn't used anything on the center tunnel, b... Dec 15 2014, 06:22 PM
GregAmy http://www.914world.com/bbs2/uploads_offsite/i1201... Dec 21 2014, 10:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:08 PM |
