brooks944 |
Member ![]() ![]() Group: Members Posts: 249 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States ![]() |
My 75 is finally home and seems to be running fine with still a bunch of body and suspension work to do. It was hard to start but now it starts after about three tries. But sometimes it won't turn over at all. Not a battery problem and it seems if I pull the key a little while starting it will catch. Is this a starter issue or ignition switch? My preference would be the cheapest of the two...
Thanks, Rick |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,454 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
My 75 is finally home and seems to be running fine with still a bunch of body and suspension work to do. It was hard to start but now it starts after about three tries. But sometimes it won't turn over at all. Not a battery problem and it seems if I pull the key a little while starting it will catch. Is this a starter issue or ignition switch? My preference would be the cheapest of the two... Thanks, Rick most likely it's the switch But do a search on ford relay .... do yourself a favor and put in the relay.... |
Lo-Fi Version | Time is now: 15th July 2025 - 04:23 AM |
