| PanelBilly |
Dec 15 2014, 11:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,964 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
Im looking for suggestions on how to plumb the fuel lines for the PMO carbs. Where should the regulator be mounted?
| slivel |
Dec 16 2014, 11:32 AM
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 545 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
Two regulators - one in front reducing the pressure to about 12 psi. Second one in engine bay on firewall reducing pressure to 4 psi. This has served me well for about 10 years.
| SLITS |
Dec 16 2014, 12:17 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
| 914Timo |
Dec 16 2014, 02:05 PM
******* ![]() ![]() ![]() Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
Wow, you used a REAL pressure regulator not the BS PMO one. Whats wrong with PMO regulators ? Are they not good ? I was just going to order one. Should I buy some other ? What's good ? Aeromotive ? At least they are expensive (IMG:style_emoticons/default/confused24.gif) |
| Mark Henry |
Dec 16 2014, 02:27 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Wow, you used a REAL pressure regulator not the BS PMO one. Whats wrong with PMO regulators ? Are they not good ? I was just going to order one. Should I buy some other ? What's good ? Aeromotive ? At least they are expensive (IMG:style_emoticons/default/confused24.gif) Ron must not like them (IMG:style_emoticons/default/confused24.gif) The Malpassi fuel regulator I'm using is favored by a lot of weber shops (Pierce Manifolds, aircooled.net, UK speed shops, etc) and should be easy for you to find in Europe. They came stock on a few cars over there as well. Made in Italy. They are real small, less than 3 inches. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.rallynuts.com-26-1418761625.1.jpg) |
| 914Timo |
Dec 16 2014, 02:45 PM
The Malpassi fuel regulator I'm using is favored by a lot of weber shops (Pierce Manifolds, aircooled.net, UK speed shops, etc) and should be easy for you to find in Europe. They came stock on a few cars over there as well. Made in Italy. Thanks Mark. Malpassi doesn´t have very good reputation here. Maybe because they are made in Italy (IMG:style_emoticons/default/biggrin.gif) But, I have to say I had Malpassi in my ´63 Beetle with dual Dellortos and zero problems with fuel pressure. |
PanelBilly Where to mount the Fuel Pressure Regulator Dec 15 2014, 11:54 PM
Socalandy I dug this picture up from when the engine was ins... Dec 16 2014, 01:04 AM
Mark Henry Doesn't really matter, but where ever you moun... Dec 16 2014, 06:53 AM
stugray In my current configuration, I have the regulator ... Dec 16 2014, 09:21 AM
Mark Henry
Wow, you used a REAL pressure regulator not the ... Dec 16 2014, 01:16 PM
SLITS
Wow, you used a REAL pressure regulator not the ... Dec 16 2014, 03:14 PM
914Timo
When you use a "safety collar"** to cl... Dec 16 2014, 03:33 PM
SLITS
When you use a "safety collar"** to c... Dec 16 2014, 03:47 PM
Mark Henry That must be very early, the ones I see now don... Dec 16 2014, 04:31 PM
patssle Or...use a fuel pump that pumps at 3-4 psi and avo... Dec 16 2014, 04:48 PM
Mark Henry
Or...use a fuel pump that pumps at 3-4 psi and av... Dec 16 2014, 04:53 PM
SLITS
Or...use a fuel pump that pumps at 3-4 psi and av... Dec 16 2014, 04:54 PM
patssle http://www.cbperformance.com/ProductDetail...roduc... Dec 16 2014, 05:27 PM
yeahmag I use the same one. I'd love to start data log... Dec 16 2014, 06:53 PM
Socalandy here's the instructions with in and out layout Dec 17 2014, 12:29 AM
PanelBilly That's perfect. I guessed the 2 lines in the f... Dec 17 2014, 12:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 12:52 PM |
