> Where to mount the Fuel Pressure Regulator
PanelBilly
post Dec 15 2014, 11:54 PM
Im looking for suggestions on how to plumb the fuel lines for the PMO carbs. Where should the regulator be mounted?
slivel
post Dec 16 2014, 11:32 AM
Old car....... older driver
Two regulators - one in front reducing the pressure to about 12 psi. Second one in engine bay on firewall reducing pressure to 4 psi. This has served me well for about 10 years.
Attached Image Attached ImageAttached Image
SLITS
post Dec 16 2014, 12:17 PM
"This Utah shit is HARSH!"
QUOTE(slivel @ Dec 16 2014, 09:32 AM) *
Wow, you used a REAL pressure regulator not the BS PMO one.
914Timo
post Dec 16 2014, 02:05 PM
Region Association: Europe
QUOTE(SLITS @ Dec 16 2014, 09:17 PM) *
Whats wrong with PMO regulators ? Are they not good ? I was just going to order one. Should I buy some other ? What's good ? Aeromotive ? At least they are expensive (IMG:style_emoticons/default/confused24.gif)
SLITS
post Dec 16 2014, 03:14 PM
QUOTE(914Timo @ Dec 16 2014, 12:05 PM) *
When you use a "safety collar"** to clamp down on a rubber hose and restrict fuel flow, it just seems mickey mouse to me. Why not use vise grips?
We used the Holley/Mr. Gasket fuel pressure regulator on the race cars and I bought them for street cars. They looked much like the ones in the picture.
**very similar to ones on the tensioners in a /6 engine to prevent total collapse.
And you are right ... I don't like them!
914Timo
post Dec 16 2014, 03:33 PM
QUOTE(SLITS @ Dec 17 2014, 12:14 AM) *
Ok. Thanks. I agree. I am not big fan of rubber hoses and hose clamps too.
According PMOs site you can buy the regulator with AN-6 fittings.
SLITS
post Dec 16 2014, 03:47 PM
QUOTE(914Timo @ Dec 16 2014, 01:33 PM) *
The one we installed on Glenn Sager's 3.0 conversion uses what I described above. If they have different ones I do not know. I'll add an image to this post in about 20 minutes.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1418767310.1.jpg)
Installed on the back firewall, between the carbs.
PanelBilly   Where to mount the Fuel Pressure Regulator   Dec 15 2014, 11:54 PM
Socalandy   I dug this picture up from when the engine was ins...   Dec 16 2014, 01:04 AM
Mark Henry   Doesn't really matter, but where ever you moun...   Dec 16 2014, 06:53 AM
stugray   In my current configuration, I have the regulator ...   Dec 16 2014, 09:21 AM
slivel   Two regulators - one in front reducing the pressur...   Dec 16 2014, 11:32 AM
SLITS   Two regulators - one in front reducing the pressu...   Dec 16 2014, 12:17 PM
Mark Henry   Wow, you used a REAL pressure regulator not the ...   Dec 16 2014, 01:16 PM
914Timo   Wow, you used a REAL pressure regulator not the B...   Dec 16 2014, 02:05 PM
Mark Henry   [quote name='SLITS' post='2123072' date='Dec 16 2...   Dec 16 2014, 02:27 PM
914Timo   The Malpassi fuel regulator I'm using is fav...   Dec 16 2014, 02:45 PM
SLITS   Wow, you used a REAL pressure regulator not the ...   Dec 16 2014, 03:14 PM
914Timo   When you use a "safety collar"** to cl...   Dec 16 2014, 03:33 PM
SLITS   When you use a "safety collar"** to c...   Dec 16 2014, 03:47 PM
Mark Henry   That must be very early, the ones I see now don...   Dec 16 2014, 04:31 PM
patssle   Or...use a fuel pump that pumps at 3-4 psi and avo...   Dec 16 2014, 04:48 PM
Mark Henry   Or...use a fuel pump that pumps at 3-4 psi and av...   Dec 16 2014, 04:53 PM
SLITS   Or...use a fuel pump that pumps at 3-4 psi and av...   Dec 16 2014, 04:54 PM
patssle   http://www.cbperformance.com/ProductDetail...roduc...   Dec 16 2014, 05:27 PM
yeahmag   I use the same one. I'd love to start data log...   Dec 16 2014, 06:53 PM
Socalandy   here's the instructions with in and out layout   Dec 17 2014, 12:29 AM
PanelBilly   That's perfect. I guessed the 2 lines in the f...   Dec 17 2014, 12:34 AM
- Lo-Fi Version Time is now: 25th May 2026 - 12:54 PM
