| PanelBilly |
Dec 15 2014, 11:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,964 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
Im looking for suggestions on how to plumb the fuel lines for the PMO carbs. Where should the regulator be mounted?
| Mark Henry |
Dec 16 2014, 04:31 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
That must be very early, the ones I see now don't look like that. They have a big chunky body with a brass adjustment screw and lock nut like in the first pic of the thread.
PanelBilly Where to mount the Fuel Pressure Regulator Dec 15 2014, 11:54 PM
Socalandy I dug this picture up from when the engine was ins... Dec 16 2014, 01:04 AM
Mark Henry Doesn't really matter, but where ever you moun... Dec 16 2014, 06:53 AM
stugray In my current configuration, I have the regulator ... Dec 16 2014, 09:21 AM
slivel Two regulators - one in front reducing the pressur... Dec 16 2014, 11:32 AM
SLITS
Two regulators - one in front reducing the pressu... Dec 16 2014, 12:17 PM
Mark Henry
Wow, you used a REAL pressure regulator not the ... Dec 16 2014, 01:16 PM
914Timo
Wow, you used a REAL pressure regulator not the B... Dec 16 2014, 02:05 PM
Mark Henry
[quote name='SLITS' post='2123072' date='Dec 16 2... Dec 16 2014, 02:27 PM
914Timo
The Malpassi fuel regulator I'm using is fav... Dec 16 2014, 02:45 PM
SLITS
Wow, you used a REAL pressure regulator not the ... Dec 16 2014, 03:14 PM
914Timo
When you use a "safety collar"** to cl... Dec 16 2014, 03:33 PM
SLITS
When you use a "safety collar"** to c... Dec 16 2014, 03:47 PM
patssle Or...use a fuel pump that pumps at 3-4 psi and avo... Dec 16 2014, 04:48 PM
Mark Henry
Or...use a fuel pump that pumps at 3-4 psi and av... Dec 16 2014, 04:53 PM
SLITS
Or...use a fuel pump that pumps at 3-4 psi and av... Dec 16 2014, 04:54 PM
patssle http://www.cbperformance.com/ProductDetail...roduc... Dec 16 2014, 05:27 PM
yeahmag I use the same one. I'd love to start data log... Dec 16 2014, 06:53 PM
Socalandy here's the instructions with in and out layout Dec 17 2014, 12:29 AM
PanelBilly That's perfect. I guessed the 2 lines in the f... Dec 17 2014, 12:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 12:51 PM |
