> Where to mount the Fuel Pressure Regulator
PanelBilly
post Dec 15 2014, 11:54 PM
Im looking for suggestions on how to plumb the fuel lines for the PMO carbs. Where should the regulator be mounted?
patssle
post Dec 16 2014, 04:48 PM
Or...use a fuel pump that pumps at 3-4 psi and avoid a high pressure fuel system and regulator.
PanelBilly   Where to mount the Fuel Pressure Regulator   Dec 15 2014, 11:54 PM
Socalandy   I dug this picture up from when the engine was ins...   Dec 16 2014, 01:04 AM
Mark Henry   Doesn't really matter, but where ever you moun...   Dec 16 2014, 06:53 AM
stugray   In my current configuration, I have the regulator ...   Dec 16 2014, 09:21 AM
slivel   Two regulators - one in front reducing the pressur...   Dec 16 2014, 11:32 AM
SLITS   Two regulators - one in front reducing the pressu...   Dec 16 2014, 12:17 PM
Mark Henry   Wow, you used a REAL pressure regulator not the ...   Dec 16 2014, 01:16 PM
914Timo   Wow, you used a REAL pressure regulator not the B...   Dec 16 2014, 02:05 PM
Mark Henry   [quote name='SLITS' post='2123072' date='Dec 16 2...   Dec 16 2014, 02:27 PM
914Timo   The Malpassi fuel regulator I'm using is fav...   Dec 16 2014, 02:45 PM
SLITS   Wow, you used a REAL pressure regulator not the ...   Dec 16 2014, 03:14 PM
914Timo   When you use a "safety collar"** to cl...   Dec 16 2014, 03:33 PM
SLITS   When you use a "safety collar"** to c...   Dec 16 2014, 03:47 PM
Mark Henry   That must be very early, the ones I see now don...   Dec 16 2014, 04:31 PM
patssle   Or...use a fuel pump that pumps at 3-4 psi and avo...   Dec 16 2014, 04:48 PM
Mark Henry   Or...use a fuel pump that pumps at 3-4 psi and av...   Dec 16 2014, 04:53 PM
SLITS   Or...use a fuel pump that pumps at 3-4 psi and av...   Dec 16 2014, 04:54 PM
patssle   http://www.cbperformance.com/ProductDetail...roduc...   Dec 16 2014, 05:27 PM
yeahmag   I use the same one. I'd love to start data log...   Dec 16 2014, 06:53 PM
Socalandy   here's the instructions with in and out layout   Dec 17 2014, 12:29 AM
PanelBilly   That's perfect. I guessed the 2 lines in the f...   Dec 17 2014, 12:34 AM
- Lo-Fi Version Time is now: 25th May 2026 - 12:51 PM
