> Subaru conversion help needed
post Dec 11 2014, 07:13 AM
914-6 GT in waiting
I'm bringing home a subaru svx in the next week or 2. Dropping it off at my mechanic to pull the engine. Besides the entire wire harness and ecu, what else should I pull from the car? Thanks, mark
rhodyguy
post Dec 17 2014, 08:23 AM
so…the EZ30 would be a direct application for my 97' legacy wagon? for a rather big car the 2.5 moves well. how cheap is cheap?
rnellums
post Dec 17 2014, 08:33 AM
Professional Enthusiast
QUOTE(rhodyguy @ Dec 17 2014, 07:23 AM) *
It will bolt up to the tranny, but unless you have an auto it will throw codes. It's definitely been done before though.
DBCooper
post Dec 17 2014, 09:02 AM
14's in the 13's with ATTITUDE
Yeah, I don't know anything more than that those inner CV's are the same. I didn't look any further so you need to check the rest, most importantly if they can even be converted to 2WD. I don't know, but if not the 2WD transmissions are there. The weight should be manageable, the length less so. I don't know why anyone would want an automatic, but if you do it's something to look at.
I thought you were talking about putting it into a 914, which is pretty straightforward. Into another Subaru is possible, they bolt up, but everything else is a lot more complicated. Look on NASIOC, there are folks who've done it, but I don't see much advantage for the amount of work involved. Those later sixes are typically a thousand bucks or less, depending on where and condition, etc. An easy search on Craigslist or eBay, see what they're worth in your neighborhood.
EDIT: Just checked eBay and they're more like $1500 or less. Craigslist around here the same or less.
mepstein   Subaru conversion help needed   Dec 11 2014, 07:13 AM
CptTripps   I'm bringing home a subaru svx in the next we...   Dec 11 2014, 07:44 AM
76-914   02 sensors off the exhaust. Don't know that en...   Dec 11 2014, 08:19 AM
mepstein   02 sensors off the exhaust. Don't know that e...   Dec 11 2014, 08:37 AM
Chris H.   I'm bringing home a subaru svx in the next we...   Dec 11 2014, 08:36 AM
CptTripps   DO NOT BOTHER wrestling the gas tank out to retri...   Dec 11 2014, 08:38 AM
mepstein   I'm bringing home a subaru svx in the next w...   Dec 11 2014, 08:40 AM
904svo   Don' get rid of the car, you will find that yo...   Dec 11 2014, 09:02 AM
mepstein   Don' get rid of the car, you will find that y...   Dec 11 2014, 11:23 AM
effutuo101   And then sell it to a recycler.   Dec 11 2014, 10:12 AM
d914   radiator mounts, misc nuts and bolts, strip it...   Dec 11 2014, 11:24 AM
mgp4591   I'm using the radiator out of my SVX in a lay-...   Dec 11 2014, 01:36 PM
904svo   I'm using the radiator out of my SVX in a lay...   Dec 11 2014, 03:34 PM
Chris H.   Mine may have been hit, but I couldn't get all...   Dec 11 2014, 03:40 PM
mgp4591   Mine may have been hit, but I couldn't get al...   Dec 12 2014, 03:19 AM
Chris914n6   Don't know how much space you have and what yo...   Dec 11 2014, 11:34 PM
mepstein   Don't know how much space you have and what y...   Dec 12 2014, 02:22 PM
76-914   The impreza pump transplants well.   Dec 12 2014, 10:16 AM
a914622   If the rear end is a 151? It's a limited slip ...   Dec 13 2014, 10:12 AM
mepstein   It has a 4.44 Legacy Transmission. That's all ...   Dec 14 2014, 04:01 PM
mgp4591   It has a 4.44 Legacy Transmission. That's all...   Dec 14 2014, 06:33 PM
DBCooper   I've driven rnellums 3.0 Subie conversion with...   Dec 14 2014, 08:25 PM
76-914   I've driven rnellums 3.0 Subie conversion wit...   Dec 15 2014, 09:51 AM
mgp4591   [quote name='DBCooper' post='2122461' date='Dec 1...   Dec 15 2014, 01:36 PM
rnellums   I've driven rnellums 3.0 Subie conversion wit...   Dec 15 2014, 09:56 PM
mepstein   [quote name='DBCooper' post='2122461' date='Dec 1...   Dec 15 2014, 10:02 PM
CptTripps   I wish I'd gone with a Subaru 6cyl in my conve...   Dec 15 2014, 10:26 AM
Chris H.   I spent an hour in and around Bob's (BIGKAT_83...   Dec 15 2014, 12:07 PM
rnellums   You can find the older (weaker) ones in the junkya...   Dec 16 2014, 05:46 AM
mepstein   You can find the older (weaker) ones in the junky...   Dec 16 2014, 06:43 AM
rnellums   If you can weld you can make your own FWD lockout ...   Dec 16 2014, 07:05 AM
mepstein   If you can weld you can make your own FWD lockout...   Dec 16 2014, 07:14 AM
76-914   If you can weld you can make your own FWD lockou...   Dec 16 2014, 09:01 AM
mepstein   [quote name='mepstein' post='2122985' date='Dec 1...   Jan 25 2015, 11:57 AM
914forme   Once I get the car together and running, it will ...   Jan 25 2015, 12:43 PM
mepstein   Once I get the car together and running, it will...   Jan 25 2015, 01:00 PM
a914622   Wait wait wait? A 4.44 trany? Did someone do a tra...   Dec 16 2014, 10:26 PM
mepstein   Wait wait wait? A 4.44 trany? Did someone do a tr...   Dec 17 2014, 07:11 AM
DBCooper   Do you intend to use an automatic? When I was tr...   Dec 17 2014, 08:14 AM
Chris H.   Do you intend to use an automatic? When I was t...   Dec 17 2014, 08:43 AM
rhodyguy   Is the 6 from the svx the same one that came in th...   Dec 17 2014, 07:46 AM
DBCooper   Is the 6 from the svx the same one that came in t...   Dec 17 2014, 08:18 AM
Chris H.   That trans is valuable to SVX guys if it's the...   Dec 17 2014, 07:58 AM
rhodyguy   so…the EZ30 would be a direct application for my...   Dec 17 2014, 08:23 AM
rnellums   so…the EZ30 would be a direct application for m...   Dec 17 2014, 08:33 AM
DBCooper   Yeah, I don't know anything more than that tho...   Dec 17 2014, 09:02 AM
mepstein   I'm checking with PO to see if rear diff was c...   Dec 17 2014, 09:11 AM
76-914   After taking one look at that monstrosity I let th...   Dec 17 2014, 09:25 AM
mepstein   After taking one look at that monstrosity I let t...   Dec 17 2014, 08:32 PM
mepstein   Engine is out   Jan 23 2015, 08:39 AM
914forme   Engine is out Good :Qarl: The cradle should be...   Jan 23 2015, 09:58 AM
mepstein   Engine is out Good :Qarl: The cradle should b...   Jan 23 2015, 10:49 PM
Chris H.   I have a TON of info on the wiring harness stuff i...   Jan 23 2015, 10:25 AM
rhodyguy   When you guys are buying donor cars and come acros...   Jan 23 2015, 10:47 AM
mepstein   When you guys are buying donor cars and come acro...   Jan 23 2015, 04:32 PM
a914622   Look good so far! Plan on changing the vacuum ...   Jan 24 2015, 09:59 AM
mepstein   Pulling the engine was easy - my local mechanic di...   Jan 24 2015, 10:18 AM
914forme   Got this chip from 914forme. Turbo boost control?...   Jan 24 2015, 03:20 PM
mepstein   Got this chip from 914forme. Turbo boost control...   Jan 24 2015, 03:37 PM
mepstein   Another part from 914forme just showed up. Coldwat...   Jan 24 2015, 02:09 PM
Chris H.   That ECU upgrade is on my list. Looks like it...   Jan 25 2015, 10:10 AM
- Lo-Fi Version Time is now: 1st August 2025 - 02:14 PM
