New item to work on. Guys with carbs what do you think?, phenolic spacers |
Mikey914 |
Dec 17 2014, 04:32 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Looking at making up some of these. These are intended to help insulate the carbs from the engine further at the carb base. Who's interested?
These were available at one time for $15 each. I should be able to do a set of 4 for $24, if i can get some quantity. Figured I'd see how much interest is out there. Attached image(s) |
r_towle |
Dec 17 2014, 06:44 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Just curious.
I have used just the head-->>manifold phenolic spacer and I have never had any heat issues on the manifolds or carbs. Sure, there is some heat from the studs, but never enough to make a big difference. Also, with these added gaskets, you are moving the throttle plate further away from the valve which does have a negative result. So, why add these? Rich |
bdstone914 |
Dec 19 2014, 08:24 AM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Just curious. I have used just the head-->>manifold phenolic spacer and I have never had any heat issues on the manifolds or carbs. Sure, there is some heat from the studs, but never enough to make a big difference. Also, with these added gaskets, you are moving the throttle plate further away from the valve which does have a negative result. So, why add these? Rich Rich What is the negative result and how is it any different than adding tall manifolds that are better for top end? Do you really think a few mm spacing will make a difference? Bruce |
Lo-Fi Version | Time is now: 31st May 2024 - 08:40 PM |
