> Is door gap widening when car is lifted normal?
doug_b_928
post Aug 10 2014, 08:10 PM
I lifted my car for the first time today. The longs have rust and the gap at the top of the door widened (the weight of the rear of the car was pulling it down such that the door gap opened more at the top (see pic below).
I'd say it was double what it is when the wheels are on the ground. So, I won't be surprised if this is because of the rust having weakened the chassis (in fact, I'm glad that it didn't snap off completely), but I'm wondering if some widening like this is normal when the car is lifted from the jack point areas (i.e., using a two post lift) and, if so, how much one should expect.
Claus Graf
post Dec 11 2014, 08:40 AM
Had I done the test of opening the doors and jumping, my 74 914 would have split in half. So I removed the engine and trans. Built a wood frame with casters and put the 914 on top. This way the car would remain aligned while I cut and rebuild the longitudinals.
worn
post Dec 21 2014, 07:52 PM
QUOTE(Claus Graf @ Dec 11 2014, 06:40 AM) *
That wood frame looks great! I made a frame that held my TR6 out of half inch plywood. If you know about racking forces and diagonals they can be super strong. This is a car for which body work is not extra expensive in materials. A big length of sheet metal, restoration designs, amig or tig and off you go. But time will be an issue. Now parts, there you can spend the money. The porsche name seems to do something to the parts.
doug_b_928   Is door gap widening when car is lifted normal?   Aug 10 2014, 08:10 PM
flash914   The car new would have none- no change. Joe Sharp ...   Aug 10 2014, 08:27 PM
Vacca Rabite   :agree: That car has cancer. Probably bad if the ...   Aug 10 2014, 08:44 PM
scotty b   bad news. All that bubbling under the gold decal i...   Aug 10 2014, 09:03 PM
doug_b_928   Yes, the car has lots of cancer. Good to know tha...   Aug 10 2014, 09:18 PM
rick 918-S   Straight to repairs. Don't mess with it too mu...   Aug 10 2014, 09:28 PM
brant   You better asses or post pics It might not be safe...   Aug 10 2014, 09:46 PM
SirAndy   Is door gap widening when car is lifted normal? ...   Aug 10 2014, 11:25 PM
Jonathan Livesay   Is door gap widening when car is lifted normal? ...   Dec 11 2014, 11:22 AM
stevegm   [quote name='SirAndy' post='2072402' date='Aug 10...   Dec 12 2014, 07:12 AM
siverson   I agree that Doug B's photo looks really bad a...   Dec 12 2014, 11:32 AM
doug_b_928   Thanks for the feedback guys. I removed the engin...   Aug 11 2014, 05:54 AM
76-914   It's time to start shopping for a CA or AZ rol...   Aug 11 2014, 07:55 AM
doug_b_928   But that would be too easy :)   Aug 11 2014, 07:59 AM
Dave_Darling   OK, then shop for a welder! --DD   Aug 11 2014, 08:18 AM
doug_b_928   Check :)   Aug 11 2014, 08:40 AM
Chris H.   And once you assess and get a welder go here: Res...   Aug 11 2014, 05:47 PM
doug_b_928   Yeah, that's the plan. BTW, the reason I...   Aug 11 2014, 05:55 PM
cary   Yeah, that's the plan. BTW, the reason I...   Dec 11 2014, 09:37 AM
stugray   the reason I'm not planning to go the roller...   Aug 11 2014, 06:11 PM
Chris H.   That's understandable. The good news is that ...   Aug 11 2014, 06:13 PM
doug_b_928   Yeah, I've already been in touch with Rick and...   Aug 11 2014, 06:20 PM
doug_b_928   Stugray, sorry I didn't see your post. This w...   Aug 11 2014, 06:23 PM
mepstein   Nothing that a lot of time and money won't fix...   Aug 11 2014, 07:47 PM
doug_b_928   Thanks. I'm eager to learn.   Aug 11 2014, 08:10 PM
SirAndy   Post some pics of your passenger side longs. In yo...   Aug 11 2014, 08:35 PM
doug_b_928   I don't have pics on this computer, but if you...   Aug 11 2014, 10:07 PM
Claus Graf   Had I done the test of opening the doors and jumpi...   Dec 11 2014, 08:40 AM
Philip W.   Had I done the test of opening the doors and jump...   Dec 11 2014, 09:00 AM
Claus Graf   Had I done the test of opening the doors and jum...   Dec 12 2014, 07:08 AM
worn   Had I done the test of opening the doors and jump...   Dec 21 2014, 07:52 PM
wndsnd   Shhhhhhhhhhhh....... Yep. and this is 8 inches [...   Dec 11 2014, 08:59 AM
IVGUY   "I noticed yesterday that it even has a block...   Dec 11 2014, 07:29 PM
Cairo94507   The good news is once you fix it correctly, you wi...   Dec 12 2014, 08:02 AM
doug_b_928   I built a bench a la Hail and put the car on it. ...   Dec 12 2014, 10:13 AM
bandjoey   Pull up the restoration thread. Many cars there sa...   Dec 12 2014, 11:27 AM
Claus Graf   This is what my longs looked like. Had some sheetm...   Dec 19 2014, 06:46 AM
siverson   I guess you just needed some thicker fiberglass...   Dec 19 2014, 05:45 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:59 AM
