Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
TheCabinetmaker |
Dec 22 2014, 02:58 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Does the idle mixture screw on the ecu make any difference?
Have you verified dwell and timing? |
lsintampa |
Dec 22 2014, 04:06 PM
Does the idle mixture screw on the ecu make any difference? Have you verified dwell and timing? Dwell and timing were checked a while back. No big changes to think they are off, but I can check it again. ECU adjustments .... I've turned that thing all the way in one direction and the other. Seems to make no difference. I don't know how sensitive that ECU adjustment is, but it seems to me that it really doesn't do much. I removed the Throttle Body and adjusted the switch using the Pelican method. At full CCW it reads 1 OHM, then I turn clockwise to Zero, then ONE more notch - OHM meter is still at ZERO at that point. Didn't seem to do much. I opened the air valve on the TB so my idle goes up to like 1500 RPM. At that speed, the surge is minor, but still present. Seems to get really wild (surging) when I try to turn in the air valve on the TB - the lower the RPM the worse the surge. IDK, It would be nice to figure out. I'm just not in the mood to yank the whole system out to check that plenum. I still think (and I'm most likely wrong) that if there were a air leak, the idle would just go high. Something I don't understand is going on. (as he states the obvious) (IMG:style_emoticons/default/confused24.gif) |
r_towle |
Dec 22 2014, 05:11 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Does the idle mixture screw on the ecu make any difference? Have you verified dwell and timing? I removed the Throttle Body and adjusted the switch using the Pelican method. At full CCW it reads 1 OHM, then I turn clockwise to Zero, then ONE more notch - OHM meter is still at ZERO at that point. Didn't seem to do much. Before you buy anything, please LOOK at the TPS as mounted, at idle, with the cover removed. |
Lo-Fi Version | Time is now: 4th June 2024 - 05:10 AM |
