Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
lsintampa |
Dec 23 2014, 12:09 PM
Well carrying on with the experiment....
Since the last setting of the TB switch caused the surge to get worse, I went back to old school and adjusted it using the Pelican method, and now the surge is much improved, but still persists. That in itself has to be a clue ?? or not, I guess. I'm gonna try the carb cleaner trick - poke about the fuel runners, plenum, etc. See if there is some suction happening where it shouldn't. I'm beginning to think that perhaps the dizzy may be the next component to inspect. But as it pertains to the dizzy, I'd think if the advance / retard were not functioning correctly, I'd have issues while driving up and down the RPM range. Car runs fine at speed, so that's why I've not suspected that the dizzy was suspect. Can't hurt to check it out though. |
Lo-Fi Version | Time is now: 4th June 2024 - 12:02 PM |
