Surge / Idle |
Surge / Idle |
lsintampa |
Dec 22 2014, 08:53 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 FI
I'm in Florida - so the weather outside is somewhat warm (50's maybe right now). I'll try to be as detailed as I can. I've had this issue since I started driving the car - about 8 months ago. It underwent a motor rebuild - along with some other mechanical repairs. All hoses are new (air supply, and fuel). ECU and other FI components are original - best I can tell. When I start the car - it starts right up. At idle RPMs go to about 1500 with a very slight surge (maybe 1450 - 1550). If I pull the air supply that goes to the AAR from the air filter and plug it, the idle goes down to what I'd expect - about 900 RPM still with a little surge. This is while the motor is "cold" - so to speak. Within like a minute of starting. As the car warms - just at idle, the RMPs start to come down and the vacuum from the AAR isn't as strong - but still present. However now the surge is crazy - like from almost a stall up to maybe 1200, back down, back up, etc. Pulling the hose from the AAR - does nothing - I can plug it or leave it and the air filter wide open and there is no change. I put the hose back on - again no change. I did not let it get to a full warm state - IE the temp gauge just started to move up. I've heard there are three states (cold, pre-warm, and fully warm) that come into play. Various tinkering, like turning the air mixture valve to a total closed state, and mucking with the ECU dial has had some success, but at BEST, I get like a 1200 RPM idle still with some surging. To the best of my knowledge there are no air leaks - at least not from any hoses. I've some concerns that the air plenum may have some stress cracks around the support studs. But I don't know that would cause the surging? I'd think the idle would just be high - period. YES / NO? I don't know where to begin to figure out why it behaves this way. Thanks, Len |
rhodyguy |
Dec 26 2014, 12:41 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,088 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If both of the tubes in the plenum spin, that means you have 4 potential leak spots. I fear you're spinning your wheels until you address them. Bite the bullet?
lsintampa |
Dec 26 2014, 12:48 PM
If both of the tubes in the plenum spin, that means you have 4 potential leak spots. I fear you're spinning your wheels until you address them. Bite the bullet? Yup, I agree... It's at that point... I'm just doing the prelim stuff - checking it out as I go. I know the AAR is fine. Been there done that. TPS - is still an open subject. Dizzy is gonna get a bath. Anyone know if the plenum can be taken out (and replaced) without taking off the intake tubes? I can easily cut the rubber hose connecting the plenum to the tubes, but putting them back on would seem difficult. Onward ho!!! |
Lo-Fi Version | Time is now: 4th June 2024 - 12:28 PM |
