Intermittent Problem with Betty's car, I am at my wit's end on this one. |
ClayPerrine |
Dec 22 2014, 07:17 PM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
About 2 weeks ago, Betty came home and said her 74, 1.8L Ljet 914 was intermittently cutting out. I took it out to test drive it, and sure enough, it will randomly cut out. Sometimes mildly, sometimes it feels like the engine shuts off completely, then turns back on.
So I started troubleshooting. Nope, grounds for the injectors are fine. Put the LM-1 in the tailpipe and had her drive it. Every time it cuts out, the LM-1 shows it going lean. I put an L-Jet tester I have on it and ran through all the tests and it shows as working fine. I had it running in the garage, and I went through a "wiggle test", wiggling every wire and connection on the engine. Nothing I do can replicate the issue in the garage. So I started throwing parts at it. To date I have replaced: The air flow meter. The fuel injection wiring harness. The double relay. The dropping resistors. The fuel pump. The ECU. The CHT. The whole distributor with a different pertronix, and tried points too. Nothing I have done to date helps. So I am hoping the collective knowledge of this place will help. I have checked all the simple stuff already. This is going to be hard to fix, whatever it is. I am now to the (IMG:style_emoticons/default/WTF.gif) stage, and looking for suggestions. |
Cap'n Krusty |
Dec 29 2014, 12:06 AM
Oh, it's around 11v, maybe 11.5, IIRC. Been a while since I looked it up.
The Cap'n |
ClayPerrine |
Dec 29 2014, 06:15 AM
Dave_Darling |
Dec 29 2014, 03:26 PM
ClayPerrine |
Dec 29 2014, 03:30 PM
I suspect it is a blown diode causing a reverse voltage spike. You've got an O-scope, don't you? Time to check the voltage with it! --DD I also have a freshly rebuilt alternator that was already scheduled to be installed on her car tonight. (IMG:style_emoticons/default/biggrin.gif) |
Dave_Darling |
Dec 29 2014, 10:44 PM
I also have a freshly rebuilt alternator that was already scheduled to be installed on her car tonight. (IMG:style_emoticons/default/biggrin.gif) I'd still suggest checking the voltage with an O-scope. It will give you more confidence that the alternator was the problem--and will tell you what kind of problem it was. --DD |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:00 AM |
