Weird (?) Dyno Results, 4-banger, Can this be legit? |
MikeInMunich |
Jan 1 2015, 07:48 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Can a few of you veterans out there please offer feedback regarding this dynograph?
This is new to me, but I am skeptical here. (IMG:style_emoticons/default/confused24.gif) Thanks! Mike in Munich Attached thumbnail(s) |
MikeInMunich |
Jan 3 2015, 09:50 AM
Hi Jeff,
Thanks for your input. I would have been specific but the engine was already done before I bought the car. I do realize that it would be recommendable to change the cam as well as the valves, etc. along with the heads. I may well just accept it as is and if I am not satisfied with its performance I may, as you suggest, eventually have an entire engine sent over here next time I re-import one. (IMG:style_emoticons/default/idea.gif) Extra space in the container goes for about $175 a cu. meter. I'm interested in opinions about HAVING to shift at 4500 or lower. Is this normal? Would it be extremely annoying? Not optimal but acceptable? Opinions? (IMG:style_emoticons/default/popcorn[1].gif) M.i.M. |
ChrisFoley |
Jan 3 2015, 10:04 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Hi Jeff, Thanks for your input. I would have been specific but the engine was already done before I bought the car. I do realize that it would be recommendable to change the cam as well as the valves, etc. along with the heads. I may well just accept it as is and if I am not satisfied with its performance I may, as you suggest, eventually have an entire engine sent over here next time I re-import one. (IMG:style_emoticons/default/idea.gif) Extra space in the container goes for about $175 a cu. meter. I'm interested in opinions about HAVING to shift at 4500 or lower. Is this normal? Would it be extremely annoying? Not optimal but acceptable? Opinions? (IMG:style_emoticons/default/popcorn[1].gif) M.i.M. There will be times when you want at least another 500 rpm. Without a build sheet for that engine its impossible to prescribe any remedy short of a complete rebuild. |
MikeInMunich |
Jan 3 2015, 10:57 AM
Hi Jeff, Thanks for your input. I would have been specific but the engine was already done before I bought the car. I do realize that it would be recommendable to change the cam as well as the valves, etc. along with the heads. I may well just accept it as is and if I am not satisfied with its performance I may, as you suggest, eventually have an entire engine sent over here next time I re-import one. (IMG:style_emoticons/default/idea.gif) Extra space in the container goes for about $175 a cu. meter. I'm interested in opinions about HAVING to shift at 4500 or lower. Is this normal? Would it be extremely annoying? Not optimal but acceptable? Opinions? (IMG:style_emoticons/default/popcorn[1].gif) M.i.M. There will be times when you want at least another 500 rpm. Without a build sheet for that engine its impossible to prescribe any remedy short of a complete rebuild. Thanks for the feedback Chris. No build sheet available at the moment. Will inquire. Have a great weekend! |
hydroliftin |
Jan 3 2015, 01:13 PM
Member Group: Members Posts: 373 Joined: 8-November 06 From: Vallejo, CA Member No.: 7,180 Region Association: Northern California |
Am I the only one noticing he is running the OBX header? I have no personal experience with them, but from what I have read they could be the problem.
MikeInMunich |
Jan 3 2015, 01:31 PM
Am I the only one noticing he is running the OBX header? I have no personal experience with them, but from what I have read they could be the problem. See reply above... Other than making them fit, what could be a problem with them? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 15th June 2024 - 11:19 AM |
