Weird (?) Dyno Results, 4-banger, Can this be legit? |
MikeInMunich |
Jan 1 2015, 07:48 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Can a few of you veterans out there please offer feedback regarding this dynograph?
This is new to me, but I am skeptical here. (IMG:style_emoticons/default/confused24.gif) Thanks! Mike in Munich Attached thumbnail(s) |
r_towle |
Jan 3 2015, 01:59 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Because it's probably a short stroke with the 1.7 or 1.8 heads, you may want to consider buying a built motor from one of our vendors here and just bolt it in place.
A 2056 motor may give you what you need. The difference between that and your motor is as follows. Larger stroke crankshaft Larger Pistons and cylinder ( Pistons will have a different pin height for the larger stroke) Most likely a different camshaft and lifters 2.0 liter heads. When you add up all those parts, and the cost to take apart the motor you have now, it may be a better use of your money to pull that motor and sell it, it's probably a decent motor, just not what you want. One of our vendors here can set you up with a long block in pretty short order and send it to your mechanic to install it. Rich |
Lo-Fi Version | Time is now: 15th June 2024 - 12:00 PM |
