| DNHunt |
Aug 28 2004, 10:31 AM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Building this has been a blast. I have certainly learned a lot. Jake has been very patient and given me plenty of rope but, when I've started to wander he's tugged me back in line.
Deck Height has been a revelation. My first attempts were all over the place. After working on this for a total of 8 hours I really believe we've got a handle on it. I've learned a bunch. First, these are very small dimensions. Jake wanted the deck within .004" on all 4 cylinders. We really struggled with this. Check this out a single sheet of paper is between .002 and .003. Attached image(s)
| DNHunt |
Aug 28 2004, 10:40 AM
When we put the cylinders and pistons on the first time, the pistons were proud of the cylinders a bunch so I couldn't torque the heads. We took some measurements but, they weren't good for anything but an approximation. So, I ordered some .140" shims from Rimco. It also was apparent that the cylinders would need to be clamped all the way around the mating surface so I got a big piece of channel iron and had it surfaced. When I used that I got the measurements with in .010. Still not good enough.
Big piece of steel. You can see how nice and even the clamping presure is from the cylinders marking the tool. Attached image(s)
DNHunt Puttin together a Raby kit engine Aug 28 2004, 10:31 AM
red914 i sure hope i can see this beauty when you are don... Aug 28 2004, 10:39 AM
DNHunt We tried switching cylinders and that didn't h... Aug 28 2004, 10:58 AM
DNHunt Here's the deck of #3 .062 at the outside edge Aug 28 2004, 11:00 AM
DNHunt Time to order some more shims. Jake said for me sh... Aug 28 2004, 11:11 AM
DNHunt Welcome to the real world son. Gerry's doin th... Aug 28 2004, 12:11 PM
thesey914 Gerry should be thankful you're letting him us... Aug 28 2004, 01:30 PM
Demick Here's the easy way to figure out the C.R.:
a... Aug 28 2004, 01:43 PM
seanery Must be really tough math! TWO Calculators... Aug 28 2004, 02:09 PM
GWN7
Porsche Rescue Ok Dave, I have no shame. What exactly is "deck he... Aug 28 2004, 04:46 PM
Brett W You will have a bigger problem with detonation at ... Aug 28 2004, 04:51 PM
LS6/914 Dave, Give a call if you need a extra hand, dial i... Aug 28 2004, 08:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th August 2026 - 06:53 PM |
