High Performance Oil Pump |
57lincolnman |
Jan 4 2015, 10:53 AM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
Should I use a high performance oil pump or go with the stock type? I have developed a minor leak with the high performance oil pump currently installed which puddles in the garage. My mechanic says the stock oil pump performs as well for standard street use and has fewer diaphragms to fail and cause leaks. This is a slightly modified 1.8L with 93 mm pistons. Do I have to drop the engine to do the swap out? Thanks for your thoughts on this.
PanelBilly |
Jan 4 2015, 11:49 AM
914 Guru Group: Members Posts: 5,819 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Pull the engine and stick a suby in there
Mark Henry |
Jan 4 2015, 12:11 PM
Pull the engine and stick a suby in there (IMG:style_emoticons/default/first.gif) I'm accused of being a "hard core six guy" so you have to pull that oil pump and install a /6. (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 06:42 AM |
