> Heat Exchangers, can any maintenance be done? (YES: updated)
malcolm2
post Jan 6 2015, 09:17 PM
I am preparing to send Dr Evil a patient, my crunchy, grindy trans. I decide to remove the exhaust and the HEs to give me some room.
The HEs are complete, but they do have some loose rusty areas. Mainly at the fan end. Even a hole in one where the axle dimple is. The welds on both ends are loose or broken. I am probably losing some heat efficiency. if there is such a thing. (IMG:style_emoticons/default/blink.gif)
Is there anything that I can do while the trans is gone to close up some holes and tighten up the seams?
I found some repair tape made for this sort of thing. I used another similar product on my 85 VW Cabriolet. I cut up a coke can and patched the hole, then wrapped it in the heat sensitive material. Once the muffler got hot it all sealed up.
Anyone do anything to these old exhausts and HEs? dealing with a '75 BTW.
Thanks,
Clark
rhodyguy
post Jan 7 2015, 07:42 AM
....and REAL heat. Do the backdate. Hardest part of the project is pulling off the late system. Lots of muffler options too.
malcolm2   Heat Exchangers   Jan 6 2015, 09:17 PM
mepstein   Sounds like a bigger problem than a coke can and d...   Jan 6 2015, 09:22 PM
malcolm2   Sounds like a bigger problem than a coke can and ...   Jan 6 2015, 09:38 PM
ndfrigi   [quote name='mepstein' post='2131031' date='Jan 6...   Jan 6 2015, 10:13 PM
colingreene   i repaired mine, it can be done.   Jan 6 2015, 09:27 PM
infraredcalvin   Whatever you use it needs to resist the high heat ...   Jan 6 2015, 09:46 PM
malcolm2   I have some FIBER FIX, but they have a style that ...   Jan 6 2015, 09:51 PM
r_towle   Best thing you could do with those is toss them in...   Jan 6 2015, 10:23 PM
rhodyguy   ....and REAL heat. Do the backdate. Hardest part o...   Jan 7 2015, 07:42 AM
malcolm2   ....and REAL heat. Do the backdate. Hardest part ...   Jan 7 2015, 10:08 AM
malcolm2   He is a picture of the early HE currently for sale...   Jan 7 2015, 10:17 AM
rhodyguy   you will need to covert to the earlier ducting sys...   Jan 7 2015, 10:17 AM
malcolm2   you will need to covert to the earlier ducting sy...   Jan 7 2015, 11:21 AM
bdstone914   [quote name='rhodyguy' post='2131192' date='Jan 7...   Jan 7 2015, 11:48 AM
r_towle   [quote name='rhodyguy' post='2131192' date='Jan ...   Jan 7 2015, 03:38 PM
monkeyboy   I am pretty sure you will need the whole kit. New ...   Jan 7 2015, 10:45 AM
rjames   Convert. It's one of the biggest 'stock...   Jan 7 2015, 10:48 AM
rhodyguy   A is where the warm air elbows attach. B is where ...   Jan 7 2015, 11:02 AM
rhodyguy   Correct on the 2.0 he's and where the pieces a...   Jan 7 2015, 11:40 AM
Chris H.   Correct sir. The 1.7/1.8 muffler flanges are curv...   Jan 7 2015, 11:41 AM
barefoot   If your CFO won't approve the backdate budget,...   Jan 7 2015, 11:50 AM
larss   I had a (good) welder to repair my heat exchangers...   Jan 7 2015, 11:51 AM
rgalla9146   Convert ! go stainless ! Price of admissi...   Jan 7 2015, 04:45 PM
stevegm   If you decide to buy a pair of HE I have a set of ...   Jan 7 2015, 05:46 PM
malcolm2   If you decide to buy a pair of HE I have a set of...   Jan 7 2015, 07:36 PM
stevegm   If you decide to buy a pair of HE I have a set o...   Jan 7 2015, 08:16 PM
mepstein   [quote name='malcolm2' post='2131430' date='Jan 7...   Jan 7 2015, 08:19 PM
stevegm   [quote name='malcolm2' post='2131430' date='Jan ...   Jan 7 2015, 08:27 PM
rhodyguy   steve, do yours have ss flanges or steel? try a ma...   Jan 7 2015, 05:50 PM
stevegm   steve, do yours have ss flanges or steel? try a m...   Jan 7 2015, 06:02 PM
colingreene   Pretty sure he means his wife.   Jan 7 2015, 06:01 PM
pilothyer   Clark.........I have a really nice set of the late...   Jan 7 2015, 08:40 PM
stevegm   Clark.........I have a really nice set of the lat...   Jan 7 2015, 08:52 PM
rjames   Clark.........I have a really nice set of the la...   Jan 7 2015, 11:58 PM
malcolm2   Clark.........I have a really nice set of the lat...   Jan 8 2015, 08:24 AM
malcolm2   Clark.........I have a really nice set of the lat...   Jan 25 2015, 10:08 AM
- Lo-Fi Version Time is now: 30th April 2026 - 06:35 PM
