| malcolm2 |
Jan 6 2015, 09:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
I am preparing to send Dr Evil a patient, my crunchy, grindy trans. I decide to remove the exhaust and the HEs to give me some room.
The HEs are complete, but they do have some loose rusty areas. Mainly at the fan end. Even a hole in one where the axle dimple is. The welds on both ends are loose or broken. I am probably losing some heat efficiency. if there is such a thing. (IMG:style_emoticons/default/blink.gif) Is there anything that I can do while the trans is gone to close up some holes and tighten up the seams? I found some repair tape made for this sort of thing. I used another similar product on my 85 VW Cabriolet. I cut up a coke can and patched the hole, then wrapped it in the heat sensitive material. Once the muffler got hot it all sealed up. Anyone do anything to these old exhausts and HEs? dealing with a '75 BTW. Thanks, Clark |
| larss |
Jan 7 2015, 11:51 AM
Member ![]() ![]() Group: Members Posts: 434 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
I had a (good) welder to repair my heat exchangers, worked out well.
/Lars S (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1420653085.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1420653087.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1420653090.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1420653093.4.jpg) |
malcolm2 Heat Exchangers Jan 6 2015, 09:17 PM
mepstein Sounds like a bigger problem than a coke can and d... Jan 6 2015, 09:22 PM
malcolm2
Sounds like a bigger problem than a coke can and ... Jan 6 2015, 09:38 PM
ndfrigi
[quote name='mepstein' post='2131031' date='Jan 6... Jan 6 2015, 10:13 PM
colingreene i repaired mine, it can be done. Jan 6 2015, 09:27 PM
infraredcalvin Whatever you use it needs to resist the high heat ... Jan 6 2015, 09:46 PM
malcolm2 I have some FIBER FIX, but they have a style that ... Jan 6 2015, 09:51 PM
r_towle Best thing you could do with those is toss them in... Jan 6 2015, 10:23 PM
rhodyguy ....and REAL heat. Do the backdate. Hardest part o... Jan 7 2015, 07:42 AM
malcolm2
....and REAL heat. Do the backdate. Hardest part ... Jan 7 2015, 10:08 AM
malcolm2 He is a picture of the early HE currently for sale... Jan 7 2015, 10:17 AM
rhodyguy you will need to covert to the earlier ducting sys... Jan 7 2015, 10:17 AM
malcolm2
you will need to covert to the earlier ducting sy... Jan 7 2015, 11:21 AM
bdstone914
[quote name='rhodyguy' post='2131192' date='Jan 7... Jan 7 2015, 11:48 AM
r_towle
[quote name='rhodyguy' post='2131192' date='Jan ... Jan 7 2015, 03:38 PM
monkeyboy I am pretty sure you will need the whole kit. New ... Jan 7 2015, 10:45 AM
rjames Convert. It's one of the biggest 'stock... Jan 7 2015, 10:48 AM
rhodyguy A is where the warm air elbows attach. B is where ... Jan 7 2015, 11:02 AM
rhodyguy Correct on the 2.0 he's and where the pieces a... Jan 7 2015, 11:40 AM
Chris H. Correct sir. The 1.7/1.8 muffler flanges are curv... Jan 7 2015, 11:41 AM
barefoot If your CFO won't approve the backdate budget,... Jan 7 2015, 11:50 AM
rgalla9146 Convert ! go stainless !
Price of admissi... Jan 7 2015, 04:45 PM
stevegm If you decide to buy a pair of HE I have a set of ... Jan 7 2015, 05:46 PM
malcolm2
If you decide to buy a pair of HE I have a set of... Jan 7 2015, 07:36 PM
stevegm
If you decide to buy a pair of HE I have a set o... Jan 7 2015, 08:16 PM
[quote name='malcolm2' post='2131430' date='Jan 7... Jan 7 2015, 08:19 PM
stevegm
[quote name='malcolm2' post='2131430' date='Jan ... Jan 7 2015, 08:27 PM
rhodyguy steve, do yours have ss flanges or steel? try a ma... Jan 7 2015, 05:50 PM
stevegm
steve, do yours have ss flanges or steel? try a m... Jan 7 2015, 06:02 PM
colingreene Pretty sure he means his wife. Jan 7 2015, 06:01 PM
pilothyer Clark.........I have a really nice set of the late... Jan 7 2015, 08:40 PM
stevegm
Clark.........I have a really nice set of the lat... Jan 7 2015, 08:52 PM
rjames
Clark.........I have a really nice set of the la... Jan 7 2015, 11:58 PM
malcolm2
Clark.........I have a really nice set of the lat... Jan 8 2015, 08:24 AM
malcolm2
Clark.........I have a really nice set of the lat... Jan 25 2015, 10:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 06:34 PM |
