Easy Alternator test? |
ChrisReale |
Nov 16 2006, 04:42 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Is there an easy multi-meter test you can do to see if the alternator has crapped out? I guess the fact that my battery doesn't charge is proof enough, but I just wanna make sure.
cary |
Jan 8 2015, 11:45 PM
Revive an old thread ..............
Just trailered the car home. Electrics went dead. Saw the volt meter dropping. Decided to pull over and have enough charge to drive it on the trailer. I was concerned earlier when I only had 12.25 volts at the battery with the car running. Wrote it off to the battery being charged with the tender. Guess not ............ I didn't notice the alternator light didn't come on when the key was on. Not Good. Went out and swapped the green to red bulbs. Bulb fired up in the green spot. So bulb is good. Pulled the #9 fuse, it was good. I did do a fuse box update to a blade type fuse panel. When its light tomorrow I'll drop the fuse panel and look at the red/white wire going to #9. Any other thoughts? |
Lo-Fi Version | Time is now: 8th June 2024 - 08:18 AM |
