| returf |
Jan 10 2015, 01:52 AM
Member ![]() ![]() Group: Members Posts: 67 Joined: 15-August 12 From: New Zealand Member No.: 14,806 Region Association: Australia and New Zealand |
I know there are a few of us with v8 powered 914 racers so I will put this to you for any info you may be able to help me with. With my first test sessions, I felt as if the rear of the car wanted to come around on light throttle through transition in corners. I have toe in on the rear and toe out (1mm total) on the front. Great turn in. My track was 90 mm wider at the front than the rear so thinking this was contributing, I modified the front suspension today to narrow the front track and are now sitting 30mm narrower at the front than the rear. I'd be interested to hear from others as to their set-ups. ( if its a real secret you can PM me haha. Any help from guys with a similar setup would be appreciated
| returf |
Jan 11 2015, 02:41 AM
Veekry9;The inner console does have doublers as well as the outer console and the shock towers.
It is running a Suretrac Helical diff. these are a tourqe biasing diff( not sure of the load required to lock up though. The engine is an LS1, pretty much standard except for fuel system upgrade, running stand alone computer, 7lbs boost, 520hp at the wheels, using an accusump to protect the engine. I have done the youtube thing but not on the chassis as yet. Racer Chris; haha. the good thing about narrowing the front is that now it will fit on my trailer easier Rich, ARB = anti roll bar. I have a blade adjustable bar at the front and a hole adjustable bar at the rear. spring rates are 6kg/mm and 8kg/mm Mike; I'm not running spacers, I installed mcphearson struts from a Nissan sylvia. Anyway the front turned in well, Everything I've done to the front end will have altered the scrub radius, but this would'nt affect the rear to any degree. Chris P.; problem only on trailing throttle midway through the corner. Drivability; with your setup you can at least get info straight from the spec boxter crowd or the cup car teams (IMG:style_emoticons/default/w00t.gif) |
| ChrisFoley |
Jan 11 2015, 07:02 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
... spring rates are 6kg/mm and 8kg/mm ... That's roughly 325 lb/in and 440 lb/in. Have you calculated the wheel rates? McPherson strut wheel rate is lower than the spring rate; trailing arm wheel rate is higher than the spring rate. Therefore, on a 914, the higher rate spring is at the front. |
returf calling v8 powered racers Jan 10 2015, 01:52 AM
veekry9 What have you done to stiffen the chassis?From new... Jan 10 2015, 05:35 AM
Mike Bellis We need to know more about your setup. Wide body o... Jan 10 2015, 11:11 AM
returf OK. the car is widebody, but will now be slightly ... Jan 10 2015, 12:44 PM
returf
If you had the time , I have a build thread fro... Jan 10 2015, 12:56 PM
veekry9 Neato.
Triangulated DOM tube cage that ties into t... Jan 10 2015, 02:16 PM
Racer Chris Add 30mm more rear tire to the outside to fix the ... Jan 10 2015, 02:36 PM
r_towle Arbs fully adjustable? What is that?
Have you corn... Jan 10 2015, 06:23 PM
Mike Bellis Based on the offset of the front wheels, you have ... Jan 10 2015, 09:00 PM
Chris Pincetich most of the best race car tips get shared in the f... Jan 10 2015, 11:49 PM
drive-ability Nice Car !
Nice to see the club members he... Jan 10 2015, 11:55 PM
messix less rear bar.
or less rebound dampening in rear ... Jan 11 2015, 02:25 AM
returf
less rear bar.
or less rebound dampening in rear... Jan 11 2015, 02:46 AM
returf
That... Jan 11 2015, 12:04 PM
Downunderman Its all in the diff. That's where I would be ... Jan 11 2015, 03:29 AM
veekry9
Its all in the diff. That's where I would be... Jan 11 2015, 08:43 AM
Mike Bellis Did you have the car corner balanced? Jan 11 2015, 12:14 PM
returf
Just roug... Jan 11 2015, 12:51 PM
messix is that with you in the car? Jan 11 2015, 12:59 PM
returf
yep, with me in it Jan 11 2015, 03:29 PM
messix regardless you need to add some more preload to th... Jan 11 2015, 01:09 PM
veekry9
Like what you did with the 2+2.Immaculate in bla... Jan 11 2015, 02:37 PM
returf
Like what you did with the 2+2.Immaculate in bl... Jan 11 2015, 03:34 PM
veekry9
That's a work of art and wouldn't be out... Jan 11 2015, 03:38 PM
returf That's a work of art and wouldn't be out o... Jan 13 2015, 02:42 AM
veekry9 Just read through the club/paddock post and see yo... Jan 11 2015, 04:27 PM
wndsrfr You noted that "problem only on trailing thro... Jan 11 2015, 07:07 PM
veekry9 A link to a Northstar DOHC 32V + G6 TX install.
Im... Jan 12 2015, 05:01 AM
veekry9 Thanks.
Machinist since '71, farmhand way befo... Jan 13 2015, 03:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:44 AM |
