> Spark plug change intervals?, Are plugs time "sensitive?"?
draganc
post Jan 14 2015, 04:24 PM
Let's assume your engine is well running.
How often do you have to change the plugs if you drive only 4-5k mls per year?
Any difference between older air cooled and h2o engines?
Thanks for the inputs!
Cap'n Krusty
post Jan 15 2015, 11:13 AM
Cap'n Krusty
Prior to 1974, the recommended plug change interval was 6K miles. That changed to 10K in 1974. I suspect with modern lead-free fuels, 15K wouldn't be out of order. You should still do a maintenance service at the intervals recommended for your car because points and filters get used up, and changing the plugs at the same time makes good sense, as they need to come out for a compression test and the plug gasket shouldn't be reused (replacement gaskets used to be available). Sand blasting the plugs REDUCES their lifespan. If you don't know the difference between a "maintenance service" and a "tune-up", bad things can happen to your car and they'll be a total surprise.
The Cap'n
- Lo-Fi Version Time is now: 1st July 2025 - 03:18 PM
