1976 Porsche 912E fuel injectors with 1.8 Ljet injection? |
Geezer914 |
Jan 16 2015, 06:07 PM
Geezer914 Group: Members Posts: 1,435 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Will 1976 Porsche 912E injectors work with 1.8 Ljet injection, on a type IV built to 2056 cu.in. with Raby RS heads and 9550 cam? I also have a 50mm VW Vanagon throttle body that I converted. I am thinking that the 912 engine being a 2.0L with Ljet injection it would add more fuel. Any opinions appreciated. (IMG:style_emoticons/default/confused24.gif)
JeffBowlsby |
Jan 17 2015, 10:42 AM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
This may help.
http://users.erols.com/srweiss/tableifc.htm A given Bosch injector is often used on several different vehicles, same Bosch PN, different vehicle specific PNs, but its the same identical injector with the same performance specs, perhaps with different hose configurations is all. The fuel needs of a specific vehicle are determined by the ECU, for that reason the same injector can be used on a 1.6L or a 2.0L engine all else being equal, because the pulse width is determined by the ECU. Knowing the injector specs allows crossover choices that may be identically compatible and are priced differently or are more available when a specific vehicle PN is hard to find. I have posted a chart somewhere for substitute 914 injector PNs... |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:18 AM |
