1976 Porsche 912E fuel injectors with 1.8 Ljet injection? |
Geezer914 |
Jan 16 2015, 06:07 PM
Geezer914 Group: Members Posts: 1,435 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Will 1976 Porsche 912E injectors work with 1.8 Ljet injection, on a type IV built to 2056 cu.in. with Raby RS heads and 9550 cam? I also have a 50mm VW Vanagon throttle body that I converted. I am thinking that the 912 engine being a 2.0L with Ljet injection it would add more fuel. Any opinions appreciated. (IMG:style_emoticons/default/confused24.gif)
Geezer914 |
Jan 18 2015, 09:40 AM
Thanks for all the info. According to the Bosch chart, the 1.8 and the 912E injectors both flow the same volume at 18.1 lbs. per hour. The Standard Motor Products 912e injectors FJ707 appear to be aluminum or SS, while the 1.8 injectors are plastic.
Just received an email from Standard Motor Products, both injectors have the same flow rate. Just as suggested, adjust the AFR with a meter. |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:37 AM |
