| jim912928 |
Aug 28 2004, 08:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Ok, my temperature gauge doesn't register at all. Car runs fine, but I really don't want to run it long without knowing what temperature range I'm running in. So, I need to begin diagnosing this problem but first I'd like to know where in the heck the temp sender is located? I'm guessing it can only be 1) wiring, 2) gauge or 3) sender. So, once I find out where the sender is how do I test it?
Car is a 75 1.8l....again, as usual...thanks in advance! |
| jim912928 |
Aug 29 2004, 03:06 PM
did a quick check..no rolled up wire under the batter tray...actually no wires under the battery tray other then the enclosded harness. I didn't lift the car up to try to find a sender.
If 1.8s did not have a temp sender then how did you know if you were overheating? There is no temp indicator in the gauge clusters...and the 75 1.8/2.0 owners manual only shows 1) oil temp gauge in the console or 2) oil temp gauge in the dash....this last one showing optional and is located where the parking brake "flasher" light is. Mine definitely doesn't have the latter. So the only temp indicator is the one in the console. Guess I have to go jack up the car and crawl underneath. |
jim912928 stupid question....temp gauge and sender Aug 28 2004, 08:00 PM
davep The temp sensor is located on the bottom of the en... Aug 28 2004, 08:04 PM
d7n7master What temp sender are you asking about? Oil or head... Aug 29 2004, 08:21 AM
jim912928 it's the factory gauge in the center console. ... Aug 29 2004, 08:29 AM
lapuwali
Brad Roberts Guy's..
Last time I checked. NO 1.8 engine ha... Aug 29 2004, 12:05 PM
jim912928 not sure if someone installed a console or not. I... Aug 29 2004, 12:48 PM
Brad Roberts All the cars have the wiring for the center consol... Aug 29 2004, 12:51 PM
Brad Roberts That wire comes out of that main harness under the... Aug 29 2004, 03:10 PM
jim912928 Ok, I think I found the "taco plate" assuming it i... Aug 29 2004, 03:37 PM
Brad Roberts You found it. Now you need to locate the wire comi... Aug 29 2004, 03:41 PM
Brad Roberts
type47 i combine "1.8" and "temp gauge doesn't work" ... Aug 29 2004, 03:46 PM
SirAndy to save money ...
oil temp sender was part of the... Aug 29 2004, 05:28 PM
jim912928 Brad,
I went out again and looked at the main wir... Aug 29 2004, 06:15 PM
SirAndy ![]() ![]() |
Lo-Fi Version | Time is now: 26th July 2026 - 03:01 AM |
