| Mueller |
Dec 5 2014, 01:05 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
I know this had been tried 7+ years ago, I was wondering if since then has anyone done a watercooled conversion and not put the radiator in the front trunk?
| timothy_nd28 |
Jan 19 2015, 07:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
Trane has been using this for decades, highly highly efficient with heat transfer but I worry about the pressure drop.
| Mueller |
Jan 19 2015, 08:03 PM
Trane has been using this for decades, highly highly efficient with heat transfer but I worry about the pressure drop. ![]() Interesting stuff.... http://www.achrnews.com/articles/90183-the...eat-coil-debate Seems like this might be a thermal issue that a professional HVAC designer should be involved in! |
Mueller Any successful radiator in engine compartment conversions? Dec 5 2014, 01:05 PM
76-914 Robert (rotary914) has. However, there is lots of ... Dec 5 2014, 02:40 PM
shoguneagle Master Mueller's "engineering mind" ... Dec 5 2014, 02:57 PM
Mueller
Master Mueller's "engineering mind... Dec 5 2014, 03:03 PM
effutuo101 My 2.5 suby turbo goes up to get the final bracket... Dec 5 2014, 03:21 PM
d914 jeep cherokee rad is like 10 x 36 and they make al... Dec 5 2014, 04:42 PM
GeorgeRud I always thought that using two small radiators in... Dec 5 2014, 04:54 PM
mepstein I would love for the radiator to work in the engin... Dec 5 2014, 07:45 PM
bulitt
I would love for the radiator to work in the engi... Dec 9 2014, 02:28 AM
I would love for the radiator to work in the eng... Dec 9 2014, 05:32 AM
Chris914n6 ^^ Countach and Diablo.
GT engine lid and some sc... Dec 5 2014, 08:00 PM
DBCooper Uh huh, that's the theory.... Dec 5 2014, 09:29 PM
effutuo101 So, running an air cooled big 6 gets enough air. W... Dec 5 2014, 09:34 PM
Mueller
So, running an air cooled big 6 gets enough air. ... Dec 5 2014, 09:49 PM
SirAndy So, running an air cooled big 6 gets enough air. W... Dec 6 2014, 11:36 PM
904svo
[quote name='Mueller' post='2118709' date='Dec 5 ... Dec 7 2014, 09:57 PM
SirAndy Here is my rear mounted radiator in my 904 kit car... Dec 7 2014, 10:04 PM
904svo
Here is my rear mounted radiator in my 904 kit ca... Dec 7 2014, 10:16 PM
Brian Mifsud
[quote name='Mueller' post='2118709' date='Dec 5 ... Jun 26 2015, 12:23 PM
Mueller
Adding to this.. the 911 engine uses Mechanical... Jun 26 2015, 04:37 PM
Brian Mifsud
hmmm, maybe we are looking at this the wrong wa... Jun 29 2015, 10:49 AM
SirAndy Years ago, at an autocross, I had to laugh at the... Jun 29 2015, 09:14 PM
Brian Mifsud
Years ago, at an autocross, I had to laugh at th... Jun 30 2015, 10:42 AM
Dave_Darling ...taking furnace ducting, and running it straight... Jun 30 2015, 09:02 AM
SirAndy water is a more efficient medium than air so
And ... Dec 6 2014, 11:41 PM
worn
And... Jun 26 2015, 07:11 PM
Dave_Darling It's also been done with an N/A Scooby motor. ... Dec 5 2014, 09:41 PM
thelogo I always though a rear spoiler with a radiator en... Dec 5 2014, 10:39 PM
r_towle Mike, don't do it.
Keep it aircooled and drive... Dec 5 2014, 10:46 PM
veekry9 https://www.google.ca/search?q=f1+chassis&a...f-e%... Dec 6 2014, 02:35 AM
veekry9
The fan is a centrifugal pump, just like any cent... Dec 6 2014, 03:10 AM
mgp4591 Interesting side rad setup... would you have that ... Dec 6 2014, 03:16 AM
veekry9
Step to the left.
Step to the right. Dec 6 2014, 04:33 AM
veekry9
Not the first. Dec 6 2014, 07:24 AM
mepstein it's easy to cool when the car is moving. It... Dec 6 2014, 07:46 AM
DBCooper Yup, lots of theory to go around, but to answer th... Dec 6 2014, 07:47 AM
veekry9 http://www.performanceforums.com/forums/sh...he-po... Dec 6 2014, 08:25 AM
76-914 I love to watch this subject resurface. A lot of a... Dec 6 2014, 10:04 AM
veekry9 "RSK must be Peter Harburg's, because the... Dec 6 2014, 11:48 AM
messix the advantage of front mount is that once the car ... Dec 6 2014, 12:35 PM
veekry9 If you planning to race it exclusively,a rad mount... Dec 6 2014, 11:24 PM
thelogo Where do water cooled 911 s mount the radiator
C... Dec 7 2014, 07:07 PM
Chris914n6 ^^ most newer mid engine cars do the corner rads a... Dec 7 2014, 08:27 PM
veekry9 http://www.fiero.nl/forum/Forum3/HTML/000116-29.ht... Dec 7 2014, 09:03 PM
mgp4591 There's alot of room for the radiator out in b... Dec 7 2014, 10:13 PM
JRust My NA 2.5 subaru leaves a bunch of room in the tru... Dec 7 2014, 10:19 PM
Andyrew I think it has all to do with the size of the moto... Dec 8 2014, 09:22 AM
thelogo How about Targa top mount
As crazy as it sounds ... Dec 8 2014, 11:32 AM
veekry9
There's alot of room for the radiator out in ... Dec 8 2014, 12:27 PM
Chris914n6 I crunched some numbers.
Based on a few sedans I ... Dec 8 2014, 12:33 PM
fiid It seems doable to do radiators in the engine bay,... Dec 8 2014, 12:34 PM
McMark Maybe a centrifugal fan on the crank wheel that bl... Dec 8 2014, 12:53 PM
SirAndy Logically, if a 3.6 can work, you should be able t... Dec 8 2014, 01:38 PM
sixnotfour :D Dec 8 2014, 02:12 PM
DBCooper The question was whether a radiator had been succe... Dec 8 2014, 03:21 PM
76-914 Paul makes a good point re: heat sink. I watched i... Dec 8 2014, 08:13 PM
Andyrew You know what would be an interesting fail safe, I... Dec 8 2014, 10:50 PM
RobW You could mount an oil cooler right behind the 914... Dec 9 2014, 12:03 AM
veekry9
You know what would be an interesting fail safe, ... Dec 9 2014, 01:06 AM
timothy_nd28 Laying a radiator flat in the front trunk?
Jan 19 2015, 01:28 AM
Mueller
Go... Jan 19 2015, 04:45 PM
Mike Bellis I had a radiator built to lay flat in the front tr... Jan 19 2015, 09:27 AM
Andyrew
I had a radiator built to lay flat in the front t... Jan 19 2015, 09:57 AM
rdauenhauer Scott Thacher was the guy who showed up in WCR 05 ... Jan 19 2015, 09:44 AM
rick 918-S
Scott Thacher was the guy who showed up in WCR 05... Jun 26 2015, 03:25 PM
Andyrew
[quote name='rdauenhauer' post='2135972' date='Ja... Jun 26 2015, 06:25 PM
DBCooper Cool, this thread came back. In the meantime I ra... Jan 19 2015, 10:05 AM
DBCooper Unfortunately a lot of rear-mount cooling projects... Jan 19 2015, 10:58 AM
3d914 OK, here's mine. Not done, but in process. I h... Jan 19 2015, 01:59 PM
Mueller Crazy idea time.....
Still have "something... Jan 19 2015, 04:57 PM
DBCooper I've seen finned aluminum tubing a bit like th... Jan 19 2015, 06:56 PM
Dave_Darling Talk to Chuck at Elephant Racing in SJ. They do m... Jan 19 2015, 07:10 PM
Mueller New Lamborghini Huracan has rear mounted radiators... Jun 26 2015, 10:45 AM
Chris H. Yes, always pull air, never push (Mike Bellis).
... Jun 26 2015, 05:22 PM
914forme Motorcycle Rads I have thought about several times... Jun 26 2015, 07:50 PM
Chris914n6 Looking at racing rads for toyota celica/mr2/spyde... Jun 29 2015, 02:39 PM
Andyrew You talking about these puppies?
http://www.ebay.... Jun 29 2015, 08:51 PM
Chris H.
http://www.ebay... Jun 29 2015, 11:40 PM
Chris914n6
http://www.ebay... Jun 30 2015, 02:15 PM
Bill D For the TD I was able to fit the radiator next to ... Jun 30 2015, 06:36 PM
Mike Bellis
For the TD I was able to fit the radiator next to... Jun 30 2015, 07:24 PM
Bill D
My project is no where near as ambitious as your... Jul 1 2015, 05:57 AM
Andyrew Impressive that you were able to make that work... Jun 30 2015, 09:42 PM
matthepcat I like it.
As I understand it the diesel runs coo... Jul 1 2015, 09:43 AM
Bill D
I like it.
As I understand it the diesel runs co... Jul 1 2015, 12:01 PM
flmont Iam considering a 4.3 ltr chevy v6 system,.with a... Jul 7 2015, 07:13 PM
Mueller Not a 914, but I think close enough, went to small... Feb 5 2017, 04:13 PM
Mueller I think what might help for any of these type swap... Feb 5 2017, 04:16 PM
mepstein Why don't you do it and report back. You don... Feb 5 2017, 06:27 PM
sotaro
Why don't you do it and report back. You don... Feb 27 2017, 09:21 PM
Rand Aren't there examples of mid-engined sports/su... Feb 27 2017, 10:03 PM
mepstein Are the radiators in boxters in the front? Feb 28 2017, 06:27 AM
Andyrew Yes. Boxsters have two small ones and boxster S... Feb 28 2017, 07:05 AM
Yes. Boxsters have two small ones and boxster S... Feb 28 2017, 07:49 AM
Andyrew
Yes. Boxsters have two small ones and boxster S... Feb 28 2017, 09:17 AM
914forme Positive pressure is king to cooling.
And there i... Feb 28 2017, 09:03 AM
Mueller Twin side mounted radiators, good enough for a big... Feb 28 2017, 04:54 PM
Twin side mounted radiators, good enough for a bi... Feb 28 2017, 07:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:16 PM |
