| jarred |
Jan 9 2015, 04:43 PM
Newbie ![]() Group: Members Posts: 25 Joined: 13-March 09 From: seattle Member No.: 10,159 Region Association: Pacific Northwest |
Designed these for my 914 and bus megasquirt projects but built a batch of 10 while I was at it in case anyone else found them useful. Specifics...
This is a 24-2 trigger wheel and sensor that mounts inside a Bosch distributor (009, 035, 050, etc) and uses a Hall effect pickup to generate a trigger signal for coil on plug or wasted spark ignition systems. Installs in 5 minutes and is much more discrete than all of those on crank 36-1 VR based systems with the brackets, etc. Tested on VW/Porsche type 4, VW type 1, and Porsche 356 and 912 engines, but will fit a broad range of Bosch 4 cylinder distributors. Can parallel two wasted spark coil packs for twin plug applications. I recommend the VW 2.0 coil pack VAG part 032905106B/032905106E which fires with logic level signals rather than requiring ignitors. Uses the Allegro 617 hall effect sensor. This sensor is internally pulled up to the power supply with a 10k resistor, so if you need a 5 volt square wave output (logic level) then power it with five volts. Need 12V? Power it with 12 Volts. 3 wires, power ground and signal all in a shielded cable ~5 feet in length. Wheel is a 24-2 which looks like a 12-1 on the crank. Will work with most Megasquirts but please do your research. I currently have 10 in stock and ready to ship. ![]() ![]() |
| jd74914 |
Jan 20 2015, 07:20 AM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,875 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I just got one of these to try out and while I haven't used it yet, the quality is very good. It really is a nice production-quality part. Thanks Jarred!
jarred FS: trigger wheel system for type 4, Megasquirt, $120 shipped Jan 9 2015, 04:43 PM
bfrymire You can verify this, but, if it fits the 914 disty... Jan 9 2015, 06:34 PM
pilothyer Could this setup also be used to trigger the injec... Jan 9 2015, 11:41 PM
jarred Bfrymire: Yes, I suspect it'll fit a lot of B... Jan 10 2015, 10:07 AM
Bob L. Pilothyer: If you only want to eliminate points, y... Jan 10 2015, 10:34 AM
jarred Bob L: Thanks. I'm not familiar with D-jet. ... Jan 10 2015, 01:54 PM
pilothyer
Bob L: Thanks. I'm not familiar with D-jet.... Jan 11 2015, 12:54 AM
Bob L. The question remains... Can this be adapted to re... Jan 10 2015, 04:04 PM
Mueller Neat setup, I like it...good price as well.
T... Jan 11 2015, 10:50 AM
restore2seater Jarred.
Sent PM with questions. Jan 10 2015, 06:20 PM
jarred My system can't do it; it was designed to repl... Jan 11 2015, 11:06 AM
Mueller
My system can't do it; it was designed to rep... Jan 11 2015, 11:11 AM
jarred Mueller: Thanks. It takes surprisingly long to de... Jan 12 2015, 12:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:53 PM |
