Just got 1972 914 where do I start |
Joe penge |
Jan 20 2015, 04:09 PM
Newbie Group: Members Posts: 23 Joined: 20-January 15 From: Illinois Chicago northern suburb Member No.: 18,342 Region Association: Upper MidWest |
New here but just picked up my first 914 it's a 1972 most original has not ran in 15 years most most kept in barn needs lots of work but where do I start?i put battery in and found that all gas lines rope braided are all leaking old fuel pump under car is bad put some Either down carb and gas pump inline to test start get thing it did start just don't stay running and kills soon as I hit gas pedal...need idea what to do first or where to start and do I try to find origanal parts?any info is good or ideas to what most of you did?
Dave_Darling |
Jan 20 2015, 06:45 PM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Do you have a single-carb setup, or the stock fuel injection?
The single-carb setup is pretty lousy, but can be made to work well enough to drive the car. First step is to replace the fuel lines. Fuel + hot engine parts == fire; FIRE BAD! Get an extinguisher while you're at it. Replace all the fluids as well. Check the brakes; they may need serious work. Being able to "go" without being able to "whoa" is not a good thing. If you can start it on ether, then you have spark and at least some compression. So what's missing is fuel. The fuel system (carb or injectors, plus the pump and any fuel lines) could be gunked up with old fuel that has turned to varnish. Lots of cleaning, rebuilding, or replacing will likely be needed to get that out. BTW, we love pics of these cars. Have any? --DD |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:19 AM |
