| jim912928 |
Aug 28 2004, 08:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Ok, my temperature gauge doesn't register at all. Car runs fine, but I really don't want to run it long without knowing what temperature range I'm running in. So, I need to begin diagnosing this problem but first I'd like to know where in the heck the temp sender is located? I'm guessing it can only be 1) wiring, 2) gauge or 3) sender. So, once I find out where the sender is how do I test it?
Car is a 75 1.8l....again, as usual...thanks in advance! |
| jim912928 |
Aug 29 2004, 06:15 PM
Brad,
I went out again and looked at the main wiring harness under the battery tray....moved it around alittle and running underneath it was the greenish wire with a male connector at the end of it (about half way up the harness right under the battery tray. So: 1. I have the wire in the rear engine compartment 2. My taco plate has the "bulge" on it with a hole for a sender 3. guess I'll have to really get under the car so I can see if there is indeed a sender in there (can't feel anything via the tip of my finger) Thanks again for the advice on what to look for. If I'm lucky, there is a sensor in there and I only need about 2 feet of wire! Jim |
jim912928 stupid question....temp gauge and sender Aug 28 2004, 08:00 PM
davep The temp sensor is located on the bottom of the en... Aug 28 2004, 08:04 PM
d7n7master What temp sender are you asking about? Oil or head... Aug 29 2004, 08:21 AM
jim912928 it's the factory gauge in the center console. ... Aug 29 2004, 08:29 AM
lapuwali
Brad Roberts Guy's..
Last time I checked. NO 1.8 engine ha... Aug 29 2004, 12:05 PM
jim912928 not sure if someone installed a console or not. I... Aug 29 2004, 12:48 PM
Brad Roberts All the cars have the wiring for the center consol... Aug 29 2004, 12:51 PM
jim912928 did a quick check..no rolled up wire under the bat... Aug 29 2004, 03:06 PM
Brad Roberts That wire comes out of that main harness under the... Aug 29 2004, 03:10 PM
jim912928 Ok, I think I found the "taco plate" assuming it i... Aug 29 2004, 03:37 PM
Brad Roberts You found it. Now you need to locate the wire comi... Aug 29 2004, 03:41 PM
Brad Roberts
type47 i combine "1.8" and "temp gauge doesn't work" ... Aug 29 2004, 03:46 PM
SirAndy to save money ...
oil temp sender was part of the... Aug 29 2004, 05:28 PM
SirAndy ![]() ![]() |
Lo-Fi Version | Time is now: 26th July 2026 - 04:25 AM |
