> Cockpit substructure, Thinking about drilling a hole through it
Randal
post Jan 22 2015, 10:00 AM
Thinking about drilling a 3/4 inch hole through the firewall to an Accusump on the other side. The Accusump will sit facing backwards towards the cockpit firewall mounted where the seat normally goes.
Anyone ever drilled through this section.
There is a black arrow where I want the hole.
All advice appreciated.
BTW I'm going to cover up that higher hole where the lines used to run to the front cooler.
McMark
post Jan 22 2015, 12:13 PM
914 Freak!
To expand on what Chris said, that area is a boxes section. So where the arrow is you would have to drill through one layer of sheet metal, and then drop into the box and drill through the next layer into the cabin.
If you drill though the dimple, those two layers of metal are back to back. But there a spot welds in the dimple. I imagine this was done for structure to tie those pieces together. If you remove the spot welds and don't compensate for it (weld around the circumference of your drilled hole) you're taking that structure away. It's probably not going to affect a caged car like yours all that much, but I'm not a big fan of it.
If I were doing it here, I would drill through the box section, then weld in a tube to make a sealed hole in the body. Then feed AN line through the hole and add the ends on after.
post Jan 22 2015, 12:22 PM
Resident German
QUOTE(McMark @ Jan 22 2015, 10:13 AM) *
Like so:
(IMG:http://www.914world.com/bbs2/uploads/post-179-1151215319.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1175805981.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1175806021.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1175806054.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1175806091.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1176965977.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1177645190.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1182813892.jpg)
Randal
post Jan 22 2015, 06:21 PM
QUOTE(SirAndy @ Jan 22 2015, 10:22 AM) *
Like so:
Nice work Andy.
What is that blue line called? Looks like it just slips on to the fittings.
Randal   Cockpit substructure   Jan 22 2015, 10:00 AM
Racer Chris   You can put a bulkhead fitting through the pocket ...   Jan 22 2015, 10:22 AM
Randal   You can put a bulkhead fitting through the pocket...   Jan 22 2015, 12:19 PM
Rob-O   :agree: What Chris said. The center of that dim...   Jan 22 2015, 10:55 AM
Randal   :agree: What Chris said. The center of that di...   Jan 22 2015, 12:19 PM
Steve   I drilled a 3/4" hole in that dimple to run t...   Jan 22 2015, 12:11 PM
McMark   To expand on what Chris said, that area is a boxes...   Jan 22 2015, 12:13 PM
SirAndy   If I were doing it here, I would drill through the...   Jan 22 2015, 12:22 PM
Kansas 914   If I were doing it here, I would drill through th...   Jan 22 2015, 12:54 PM
Randal   If I were doing it here, I would drill through th...   Jan 22 2015, 06:21 PM
SirAndy   What is that blue line called? Looks like it just...   Jan 22 2015, 08:17 PM
Mark Henry   What is that blue line called? Looks like it jus...   Jan 22 2015, 11:13 PM
Randal   [quote name='SirAndy' post='2137301' date='Jan 22...   Jan 23 2015, 06:58 PM
SirAndy   Isn't that Parker Pushlok hose? The Parker Pu...   Jan 23 2015, 07:28 PM
JRust   :agree: That's is effective & looks good....   Jan 22 2015, 06:03 PM
Racer Chris   Aeroquip AQP Socketless Hose   Jan 22 2015, 07:28 PM
Randal   Aeroquip AQP Socketless Hose Sure looks like a ...   Jan 22 2015, 10:21 PM
SirAndy   the pliers to crimp the clamps, recommended in hi...   Jan 22 2015, 10:40 PM
Randal   the pliers to crimp the clamps, recommended in h...   Jan 22 2015, 10:56 PM
- Lo-Fi Version Time is now: 8th December 2025 - 02:50 AM
