Lookie what I got in the mail today, Some very impressive work |
Woody |
Jan 22 2015, 05:53 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I've been building a 2414 race engine for my car and the old Kerry Hunter setup just wasn't going to cut it. I emailed Chris Foley and we began discussing what would be needed for my build and here it is. Turn around time was pretty fast for a custom exhaust, I ordered it a late last month. Since then I have ordered several other things from him such as his ITG air cleaner kit, his oil pressure relief assembly, a Mallory distributor, his cable throttle kit, and his new basic oil cooler kit. It has been an absolute pleasure dealing with him. Heres some pics for y'all to drool over.
bigkensteele |
Jan 22 2015, 07:49 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Just curious about the stub setup. Do you fasten the stubs to the header for the initial fit to get everything aligned, fasten to the motor, and then after that, you only need to remove the header from the stubs to take the exhaust off?
In other words, I am assuming that the purpose of the stub pipes is to facilitate easy and frequent removal of the exhaust without disturbing the copper gaskets and fussy head studs. Is that assumption correct? Oh, yeah, very sweet pipes! |
ChrisFoley |
Jan 22 2015, 09:12 PM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
In other words, I am assuming that the purpose of the stub pipes is to facilitate easy and frequent removal of the exhaust without disturbing the copper gaskets and fussy head studs. Is that assumption correct? Yes, that's part of the value of these stub pipes. They're made with a taper that closely matches the actual port opening at the top and the primary tube at the bottom. Smoothing out the flow there facilitates the scavenge wave technology behind my header design. If one wants to have the heads ported and flowed, installing the stubs first is much better than doing the work without them. |
Lo-Fi Version | Time is now: 12th June 2024 - 09:30 AM |
