> Subaru conversion help needed
post Dec 11 2014, 07:13 AM
914-6 GT in waiting
I'm bringing home a subaru svx in the next week or 2. Dropping it off at my mechanic to pull the engine. Besides the entire wire harness and ecu, what else should I pull from the car? Thanks, mark
post Jan 24 2015, 10:18 AM
914-6 GT in waiting
Pulling the engine was easy - my local mechanic did it for me. Next step is to pull the chassis harness. That's my job.
Got this chip from 914forme. Turbo boost control? I don't know?
914forme
post Jan 24 2015, 03:20 PM
QUOTE(mepstein @ Jan 24 2015, 11:18 AM) *
Its an argumentation to the stock ECU, ECUTune stage 1. If you need more you can upgrade it to stage 2, that will give you dual fuel maps, if you every want to run E85 (IMG:style_emoticons/default/happy11.gif)
Overview od stage 1
Features
More aggressive timing profile for more torque
Built in fix for M/T stalling when stopped
Improved power band with increased low rpm torque
7800 rpm rev limit
No vehicle speed limiter
Eliminates hesitation when shifting
Great for SVX automatics, SVX 5 speeds and SVX powered Vanagons 914s (IMG:style_emoticons/default/aktion035.gif)
Stage two requires new injectors, MAP etc...
mepstein   Subaru conversion help needed   Dec 11 2014, 07:13 AM
CptTripps   I'm bringing home a subaru svx in the next we...   Dec 11 2014, 07:44 AM
76-914   02 sensors off the exhaust. Don't know that en...   Dec 11 2014, 08:19 AM
mepstein   02 sensors off the exhaust. Don't know that e...   Dec 11 2014, 08:37 AM
Chris H.   I'm bringing home a subaru svx in the next we...   Dec 11 2014, 08:36 AM
CptTripps   DO NOT BOTHER wrestling the gas tank out to retri...   Dec 11 2014, 08:38 AM
mepstein   I'm bringing home a subaru svx in the next w...   Dec 11 2014, 08:40 AM
904svo   Don' get rid of the car, you will find that yo...   Dec 11 2014, 09:02 AM
mepstein   Don' get rid of the car, you will find that y...   Dec 11 2014, 11:23 AM
effutuo101   And then sell it to a recycler.   Dec 11 2014, 10:12 AM
d914   radiator mounts, misc nuts and bolts, strip it...   Dec 11 2014, 11:24 AM
mgp4591   I'm using the radiator out of my SVX in a lay-...   Dec 11 2014, 01:36 PM
904svo   I'm using the radiator out of my SVX in a lay...   Dec 11 2014, 03:34 PM
Chris H.   Mine may have been hit, but I couldn't get all...   Dec 11 2014, 03:40 PM
mgp4591   Mine may have been hit, but I couldn't get al...   Dec 12 2014, 03:19 AM
Chris914n6   Don't know how much space you have and what yo...   Dec 11 2014, 11:34 PM
mepstein   Don't know how much space you have and what y...   Dec 12 2014, 02:22 PM
76-914   The impreza pump transplants well.   Dec 12 2014, 10:16 AM
a914622   If the rear end is a 151? It's a limited slip ...   Dec 13 2014, 10:12 AM
mepstein   It has a 4.44 Legacy Transmission. That's all ...   Dec 14 2014, 04:01 PM
mgp4591   It has a 4.44 Legacy Transmission. That's all...   Dec 14 2014, 06:33 PM
DBCooper   I've driven rnellums 3.0 Subie conversion with...   Dec 14 2014, 08:25 PM
76-914   I've driven rnellums 3.0 Subie conversion wit...   Dec 15 2014, 09:51 AM
mgp4591   [quote name='DBCooper' post='2122461' date='Dec 1...   Dec 15 2014, 01:36 PM
rnellums   I've driven rnellums 3.0 Subie conversion wit...   Dec 15 2014, 09:56 PM
mepstein   [quote name='DBCooper' post='2122461' date='Dec 1...   Dec 15 2014, 10:02 PM
CptTripps   I wish I'd gone with a Subaru 6cyl in my conve...   Dec 15 2014, 10:26 AM
Chris H.   I spent an hour in and around Bob's (BIGKAT_83...   Dec 15 2014, 12:07 PM
rnellums   You can find the older (weaker) ones in the junkya...   Dec 16 2014, 05:46 AM
mepstein   You can find the older (weaker) ones in the junky...   Dec 16 2014, 06:43 AM
rnellums   If you can weld you can make your own FWD lockout ...   Dec 16 2014, 07:05 AM
mepstein   If you can weld you can make your own FWD lockout...   Dec 16 2014, 07:14 AM
76-914   If you can weld you can make your own FWD lockou...   Dec 16 2014, 09:01 AM
mepstein   [quote name='mepstein' post='2122985' date='Dec 1...   Jan 25 2015, 11:57 AM
914forme   Once I get the car together and running, it will ...   Jan 25 2015, 12:43 PM
mepstein   Once I get the car together and running, it will...   Jan 25 2015, 01:00 PM
a914622   Wait wait wait? A 4.44 trany? Did someone do a tra...   Dec 16 2014, 10:26 PM
mepstein   Wait wait wait? A 4.44 trany? Did someone do a tr...   Dec 17 2014, 07:11 AM
DBCooper   Do you intend to use an automatic? When I was tr...   Dec 17 2014, 08:14 AM
Chris H.   Do you intend to use an automatic? When I was t...   Dec 17 2014, 08:43 AM
rhodyguy   Is the 6 from the svx the same one that came in th...   Dec 17 2014, 07:46 AM
DBCooper   Is the 6 from the svx the same one that came in t...   Dec 17 2014, 08:18 AM
Chris H.   That trans is valuable to SVX guys if it's the...   Dec 17 2014, 07:58 AM
rhodyguy   so…the EZ30 would be a direct application for my...   Dec 17 2014, 08:23 AM
rnellums   so…the EZ30 would be a direct application for m...   Dec 17 2014, 08:33 AM
DBCooper   Yeah, I don't know anything more than that tho...   Dec 17 2014, 09:02 AM
mepstein   I'm checking with PO to see if rear diff was c...   Dec 17 2014, 09:11 AM
76-914   After taking one look at that monstrosity I let th...   Dec 17 2014, 09:25 AM
mepstein   After taking one look at that monstrosity I let t...   Dec 17 2014, 08:32 PM
mepstein   Engine is out   Jan 23 2015, 08:39 AM
914forme   Engine is out Good :Qarl: The cradle should be...   Jan 23 2015, 09:58 AM
mepstein   Engine is out Good :Qarl: The cradle should b...   Jan 23 2015, 10:49 PM
Chris H.   I have a TON of info on the wiring harness stuff i...   Jan 23 2015, 10:25 AM
rhodyguy   When you guys are buying donor cars and come acros...   Jan 23 2015, 10:47 AM
mepstein   When you guys are buying donor cars and come acro...   Jan 23 2015, 04:32 PM
a914622   Look good so far! Plan on changing the vacuum ...   Jan 24 2015, 09:59 AM
mepstein   Pulling the engine was easy - my local mechanic di...   Jan 24 2015, 10:18 AM
914forme   Got this chip from 914forme. Turbo boost control?...   Jan 24 2015, 03:20 PM
mepstein   Got this chip from 914forme. Turbo boost control...   Jan 24 2015, 03:37 PM
mepstein   Another part from 914forme just showed up. Coldwat...   Jan 24 2015, 02:09 PM
Chris H.   That ECU upgrade is on my list. Looks like it...   Jan 25 2015, 10:10 AM
- Lo-Fi Version Time is now: 1st August 2025 - 02:06 PM
