Just got 1972 914 where do I start |
Joe penge |
Jan 20 2015, 04:09 PM
Newbie Group: Members Posts: 23 Joined: 20-January 15 From: Illinois Chicago northern suburb Member No.: 18,342 Region Association: Upper MidWest |
New here but just picked up my first 914 it's a 1972 most original has not ran in 15 years most most kept in barn needs lots of work but where do I start?i put battery in and found that all gas lines rope braided are all leaking old fuel pump under car is bad put some Either down carb and gas pump inline to test start get thing it did start just don't stay running and kills soon as I hit gas pedal...need idea what to do first or where to start and do I try to find origanal parts?any info is good or ideas to what most of you did?
Joe penge |
Jan 24 2015, 05:04 PM
Ok turned key and started right up today so I changed oil and filter today and tested first gear and reverse both did great and stoped but now fuel is leaking from hose on fuel injectors and at the base of intake so ordered all the parts to take out and redo 45 fuel line upper and lower seal and spring washer ..regulator is not leaking so will try to keep old ones in but drove 100 ft front and backwards so think it's on a good path is it easy to do injector redo parts?
Lo-Fi Version | Time is now: 23rd May 2024 - 07:47 AM |
